82 accept 85 impact bar
Old Jan 16, 2020 | 01:09 PM
jbmillerj's Avatar
We are building an 82 pro street car but are putting 85 front end on it with the ground effects. Question is, will an 85 impact bar bolt up to an 82? Thank you!
Old Jan 16, 2020 | 01:36 PM
Drew's Avatar
Re: 82 accept 85 impact bar
It should. People change the bumper covers all the time without issue. Really the 85 front should go on without changing the impact bar.
Old Jan 16, 2020 | 03:44 PM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
No you have to change the impact bar to the 85-up one. There is just enough difference to not let the nose fit right. The bar might be the same but pretty sure the honeycomb that is mounted to it that is the issue.
Old Jan 16, 2020 | 04:34 PM
Drew's Avatar
By the book there are four impact bumper part numbers 82-86. Now the question you have to ask is what's the difference? The book doesn't really say. At least this half of the book doesn't say, and I honestly don't feel like pulling out the 3-ring binders to see if the other half explains what's different. What I can say is I've seen a lot of early cars with later bumper covers that were put together by people that would never think to change the impact bar. I'd expect the differences between the three part numbers include at least one version that's aluminum, and might include things that are as minor as having the holes drilled to mount the fog lights.
So then does the impact bumper need to be changed? Maybe. If it does it'll should bolt right on.
Old Jan 22, 2020 | 10:14 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
YUP. The same thing is true when dealing with the rear impact bar; the honeycomb is different on Coupe, IROC style, & 90-92 Z28 style.
seiplentz
Sep 1, 2018 12:59 PM
LS2Swapped92
Feb 3, 2018 06:56 AM
1bad406
May 23, 2005 04:25 PM
mw66nova
Dec 23, 2004 01:20 PM
TransAm12sec
Aug 16, 2004 09:19 PM
