Rear Hatch Bolts
Old Feb 2, 2020 | 04:16 PM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Rear Hatch Bolts
Hello fellow third geners. Have a question, the plastic is coming up on the rear hatch bolts in the glass. Is it easy to just replace them. Kinda scared. Dont want to shatter the glass. Tried looking on YouTube and couldnt find a video on it. Thanx and have a good day
Old Feb 2, 2020 | 05:12 PM
Firebirdwade's Avatar
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Re: Rear Hatch Bolts
Are you talking about the little plastic washers between the bolts and the glass? Do you have any pictures?
Old Feb 2, 2020 | 07:47 PM
my82roc's Avatar
Car: 89 Iroc Convertible
It’s not too hard.Just don’t crank them down too tight.I use a 13 mm ratchet wrench to do them
Old Feb 3, 2020 | 08:17 AM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Ok so just dont overtighten them. Got it. Thank u all for your responses.
Old Feb 3, 2020 | 08:50 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
x2
Got mine through Hawks on fleabay.
For ease of install, I chose to unhook the hatch struts and used a trash can that was conveniently the right height/strong enough to hold it up so I could change the bolts out and also adjust the hatch.
Hope that helps.
Old Feb 3, 2020 | 10:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Glass-to-Hinge bolts: 11 ft-lb
Old Feb 6, 2020 | 08:37 PM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Omg Paulo that is awesome!!! Thanx for sharing that info
camaro211z28
Sep 28, 2017 06:36 AM
DanDingo32
Apr 21, 2012 10:29 PM
Donald87FB
Oct 3, 2009 04:56 PM
Hunnicuttz
Jan 19, 2008 03:23 PM
bigdog 717
Oct 1, 2005 09:26 PM
