Another 88 gta question about side markers
Old Feb 5, 2020 | 12:33 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Are my front side marker lights the same as the rear sides
fit wise
I can buy nice clear housings on eBay for only the front sides
but nothing for the rear sides
now will the front side fit in the rears
it will look dumb if I just get front sides
ty
Old Feb 5, 2020 | 01:34 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Another 88 gta question about side markers
The front are different sizes than the rear. I also wanted to do like you're suggesting, but it won't work to just drop in. I got a set of junk fenders and I cut the metal out and will be welding it into the quarters so I can run clear markers all the way around
Old Feb 5, 2020 | 02:27 PM
bensbaby's Avatar
Engine: 383 built
ok great
ty
at least I know
Drew's Avatar
Back in the old days, if you wanted clear lights or tinted lights, you could remove the lens and cut a new one from plexi or polycarbonate. The only catch here is you'd lose the diffuser and integral reflector.
Old Feb 5, 2020 | 04:51 PM
bensbaby's Avatar
Engine: 383 built
how did the clears hold up for not leaking water
quality wise
Old Feb 5, 2020 | 07:00 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I haven't done it yet. They probably won't hold back water though since there is no gasket. I was going to figure something out, but that would a fair weather car from that point anyway. Washing it would be most of the water it would see
Old Feb 5, 2020 | 10:37 PM
bensbaby's Avatar
Engine: 383 built
I ment do the ebay clears leak water into the lens sometimes the glue they put on leaks water or moisture after 1 month sometime never
I have had mixed results I was just curious before I bought a set
Old Feb 6, 2020 | 02:10 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Back in the day my buddy did this for his mk2 jetta but used a chunk of diffused cover from a kitchen florescent fixture. Didn't look too bad.
I bought a set of cleared firebird assemblies from a forum members years and years ago because he had a set of front clears I wanted. I never installed them because my car is red so the rears blend in but I can almost guarantee they have been lost in the bowels of my garage. They didn't look too difficult to make?
Chet
Apr 10, 2002 06:18 AM
GTA-88
Apr 23, 2001 09:17 AM
