Z28?
Re: Z28?
Car: 1984 Z28
Engine: 305 HO
Transmission: 5 Speed
Axle/Gears: 3.23 Truetrac; was better w/ 3.73
Re: Z28?
Z28 will not be on the tag [edit: of a Van Nuys car]. Your best clues will be how the GFX are attached and if they appear original to the car, including front and rear bumper covers mismatched paint, poor fit, welding on side GFX supports and studs). Also look for the right fender to cowl brace and left fender liner to frame rail brace. And there will be triangle braces [edit: from the K member and inside of frame rails].
Car: 1987 IROC Z28
Engine: 5.0 liter
Transmission: 700R-4
Axle/Gears: 273 posi trac
Re: Z28?
This is a pic of the tag on the radiator support on my '83 Z28 (Z28 located below the left mounting rivet). Mine is a Norwood assembled car, so not sure if yours will be the same or not.
Check this website for help decoding your '83
http://www.camarotech.com/VIN-codes-Camaro-1983.html
