this may be stupid but......
Old Feb 16, 2002 | 10:00 PM
90CamaroRSGuy16's Avatar
Can an 89 just be a z-28??? or was the Z-28 an IROC?? Was the IROC a package added to a Z-28 to make it an IROC-Z, if so, what did the package include?
Old Feb 16, 2002 | 11:38 PM
92GTA's Avatar
IROC-Z was a package for the Z-28 just like the GTA was a package for the Trans Am. One of the Camaro guys will fill you in on the package options......
Old Feb 16, 2002 | 11:40 PM
karfreek's Avatar
1987 was the last year for the Z28 till 1991. No exceptions.
Jay
Old Feb 17, 2002 | 01:02 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
85-87: Z28 and IROC-Z28 (option).
88-90: IROC-Z28 only.
It is a Z28 yes, an upgraded Z28.
Old Feb 17, 2002 | 08:06 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The IROC-Z (RPO B4Z) was an option on the Z28 in 1985 thru 1987. It is a graphics and suspension/handling option. It consists of body-colored lower rockers, specific striping and door decals.
The factory fog lamps originated on the 1985 IROC-Z but was made available on all Camaro variants beginning in 1986. For 1987, it was not available on the RS or Sport Coupe (with the exception being the Sport Coupe with the LT option). The suspension included specifically valved front struts, Delco-Bilstein rear shocks, and a frame stabilizer called the "wonderbar". It also included 16-inch wheels and tires, which necessitated a steering gear box with closer "stops" to prevent the larger tires from rubbing in the fenderwells. The rear springs and sway bar diameters between the Z28 and Z28 with IROC-Z option are identical, although the IROC-Z's stance is 15mm lower. Whether it be a Z28 or a Z28 with the IROC-Z option, "Z28" was used for all exterior badging.
For 1988, the Z28 was discontinued. The IROC-Z became the "base" sport model. Exterior badging changed to read "IROC-Z. GM was so cheap that the interior dash badging was not retooled. So these cars' interior badging reads "Z28/IROC-Z" just as in previous years. In 1988, the 15-inch Z28 wheels (previously used on 1982 to 1987 Z28's) became the standard IROC-Z wheel. The 16-incher was an option. This was true for 1989 also except the '89 15-inch wheel is identical in style to the 16-inch wheel.
The RPO code used for the IROC-Z in previous years, B4Z was no longer used. Instead, RPO Z28 was used for all 1988 - 1990 IROC-Z's.
Old Feb 17, 2002 | 03:19 PM
Administrator
Originally posted by Willie
Whether it be a Z28 or a Z28 with the IROC-Z option, "Z28" was used for all exterior badging. (85-87)
I don't know. They had to do a few things to remind u that it is still a Z28 by doing that and using Z28 for the RPO. We know it means IROC-Z28, but I've been asked more than a few times what the Z stands for in IROC-Z. (been asked what IROC means enough too ) Its better that they kept it on there.
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
