T-Top Outer Trim Repair/Replace (1991)
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: T-Top Outer Trim Repair/Replace (1991)
It's replaceable.... gotta' basically re-build the T-Top but it's certainly do-able. The early/mid eighties cars used a rubber ( or rubber like ) drip-edge and around 90-or-so it was changed to a style that was more firm / rigid. ( more like plastic than rubber IMO )
I've got couple pics posted and another member posted a video here:
https://www.thirdgen.org/forums/body...drip-edge.html
Engine: LS1, LB9, L03
https://www.hawksmotorsports.com/t-t...plastic-style/
Not very difficult to replace, you will need a torx bit to get the handles off the t-tops though. Pretty self-explanatory other than that.
