Faded plastic trim
Old Apr 20, 2020 | 06:14 PM
red92convert's Avatar
Car: 1992 RS 25th anniv convertible
Engine: 5.0 TBI
Faded plastic trim
I have a 1992 RS 5.0 convertible; the red paint is all original and in pretty good shape. The problem I have is with the two (plastic, fiberglass?) pieces on top of the body that extend from the door openings to the rear spoiler. I don't even know what they are actually called but they are constantly exposed to the sun and are now starting to oxidize and fade. I tried using polishing compound on them but it didn't help much. I have read that the new ceramic coating products might work but I wanted to consult the experts to see if anyone can tell me what to use to clean up these pieces. Any advice is greatly appreciated, thanks...
Old Apr 20, 2020 | 06:21 PM
Billgluckman's Avatar
Re: Faded plastic trim
Post pics. Your clear coat is probably failing.
Old Apr 20, 2020 | 06:39 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
I don’t believe he’s talking about the quarter panel but rather the plastic trim that covers the half the wheel well and rear hatch area. Come to think of it I can’t think of what it’s called either 🤔
I’m sure as soon as someone posts it’s technical name I’ll be like ahhh yeah lol.
As far as your original question I’m of no help there, but also curious what others have done to restore these parts as well.
Old Apr 20, 2020 | 07:14 PM
BuckyBadgerRS's Avatar
Car: 91 Rs
Engine: 327 SBC
If the clear is starting to break down or peel all you can do is refinish them. However if they are just looking dull or chalky an actual buff with a wool pad and compund followed by a foam pad and polishing compound will restore the shine. If I had to guess you are dealing with the paint actually breaking down from UV exposure and it will need to be removed and repainted
Old Apr 26, 2020 | 12:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
He's talking about the spoiler extensions that run along the to top the qtr panel, up to the door jamb...sounds like....and sounds like its time for a repaint/clear coat. If it were me i would just rattle can them back to "new".
Old Apr 26, 2020 | 04:48 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
With such a small surface, rattle can in your paint color from a good supplier will work fine. Then clear on top, buff and you will be amazed at how well they will look. I have done several small areas like this(including my entire rear bumper) with very good results. I have used "automotivetouchup.com" from Louisianna and they have always matched my color perfectly. As for what they are called, I just refer to them as parts of the spoiler. (left side spoiler, right side spoiler, and center spoiler for the 3 pieces). One can should be plenty.
Tootie Pang
Apr 17, 2017 05:29 PM
83 Crossfire TA
Apr 2, 2014 09:33 PM
Iroctopless
Interior Parts Wanted
Jul 17, 2007 05:21 PM
92rs85berlintta
Dec 16, 2004 07:12 AM
Hummer
Jun 13, 2001 07:10 AM
