Re-attaching inside door felts
How do you re-attach them to the top plastic trim piece?
From the factory they are held by a few heavy staples and some heat deformed plastic rivets, neither of which really end up reusable (the rivet heads pop of if you mess with them, and the staples are too ridged to be unbent/bent).
I've thought about screws or rivets, but I'm a bit worried that they'd scratch the glass/crack the plastic.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Re-attaching inside door felts
Epoxy plastic weld where the factory did the melt rivet thing.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
On my car where the plastic nubs were hidden I just drilled them out and
used pop rivvets to hold it all together.
No problems with scratching the glass.
Car: 1983 Z28
Engine: 385 Fastburn
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I use heavy/thick staples, similar to the ones the factory used.... just that I'll use about 5 of them rather than the 1 or 2 that the factory used.
I'll set the weatherstrip in place then drill a few tiny holes thru it and the upper door trim so each staple will push right thru by hand, then fold the staples from the backside. Never had to re-visit that type of repair once completed.
Any heavy staple will do. IIRC the last time I did this I got the staples from a large appliance box. ( they just happened to be perfect for the job ! ) The factory used some pretty strong staples and the original ones are not always easy to remove,..... without destroying the plastic anyway !
GM should have used staples along the whole strip rather then 'plastic-welding' the studs IMO.
Numbah-1
Sep 12, 2015 08:57 PM
