Will a 1985 Fender fit my 1982 firebird?
Old Jun 8, 2020 | 08:31 PM
82Firebird5.0's Avatar
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
Got hit when turning, fender is messed up. Can’t seem to find whether a 1985 fender wl work and the 1982s are few and far between. Can somebody tell me how the 82-84 fenders are different than the 85-92s and whether one would work? Thanks so much I’m so sad this happened
Old Jun 8, 2020 | 09:07 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Will a 1985 Fender fit my 1982 firebird?
Burb.
Old Jun 8, 2020 | 09:42 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Originally Posted by -=Z28=-
Burb.
what?
Old Jun 8, 2020 | 09:52 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
Yes, it will physically fit.
You will have to have the 5 holes for the 85 ground effects welded up though.
The hole for the fender vent is the same as the 82-84.
Thanks,
Chris
Old Jun 8, 2020 | 09:53 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
i was assuming the 85 trans am fender. the firebird fenders should be the same 82-92
Old Jun 9, 2020 | 07:59 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Thanks,
Chris
when you say physically fit is there another way for it to fit? Mine is a non trans am so will a 1985 non trans am fender work ? Some people say there’s a lip that’s shaped differently
Old Jun 9, 2020 | 08:02 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
also some people say that there’s different mounting holes, is this true?
I found this, will it just bolt up? https://www.carparts.com/details/Pon...86/8303-1.html
Old Jun 9, 2020 | 04:58 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
This is quite possibly the best question ever asked on TGO.
Old Jun 9, 2020 | 05:23 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
they are physically the same size. some mounting holes could vary, but that is true of any aftermarket panel.
Old Jun 9, 2020 | 05:24 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
i am planning to use 85-90 ta fenders on the 84 we are rebuilding. just gonna weld up the 5 small gfx holes.
later,
Chris
Old Jun 9, 2020 | 05:32 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
I don't know all of the specifics of the fenders throughout the years or if this helps you, but I installed 82 Trans Am fenders on a 91 Trans Am GTA for a buddy and they bolted right on. There was no elongating of any holes or re-drilling any mounting holes. They went right on using the original bolts from the 91.
Last edited by kentuckyKITT; Jun 9, 2020 at 05:34 PM. Reason: can't spell, probably still wrong, but oh well.
kevins_84_bird
Apr 12, 2009 06:23 PM
ranone21
May 15, 2007 05:59 PM
phoenix85
Jan 11, 2005 06:07 PM
raptor.gta
Jun 2, 2004 10:41 PM
