Door latch adjustment technique #58
Old Nov 10, 2020 | 12:23 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Well guys, my passenger side door was banging around over bumps. For some reason driver side does not. The only thing that seems to be the difference, is I am 100 lbs heavier than my wife. everything else seems to be the same. this is with T-tops off, windows down.
Anyway, cutting to the chase, I appear to be missing the 2 white rollers in the hinge. Since they changed the design from 89-92, there is no aftermarket available. Not sure if one can buy an aftermarket and remove the rollers to get it right. Anyway, what I did was cut two ~1" pieces of 5/8" vacuum hose, and jam them in there, one on top of the other. No more banging!
Cut them so the door will close easily, but not any shorter. Hope this helps someone.
Old Sep 16, 2021 | 03:47 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Door latch adjustment technique #58
Curious what you are talking about?
any pics?
My 89 does some banging on the passenger side
Old Sep 16, 2021 | 04:01 PM
LiquidBlue's Avatar
Transmission: MD8
no pics, but basically just cut some hose to length, and placed it in there so it surrounds the striker when the door is closed. think I used 1/2" start with a little and you'll get it figured out. just keep cutting it down until it works like you want. and dont slam door until you know it won't catch on the rubber. actually, never slam doors, they should shut easily with just a nudge!
Sure wish someone would sell me a good latch!
Old Sep 16, 2021 | 04:23 PM
1989karr's Avatar
Engine: 3.4 / 5.0
So you put it into the latch part?
Im guessing the area where the "head" of the striker goes into the latch?
Old Sep 16, 2021 | 05:21 PM
LiquidBlue's Avatar
Transmission: MD8
sounds about right, forget exactly how I did it now. many moons ago.
Old Sep 16, 2021 | 05:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
thx! will try!
tealcamaromanrs
Jul 8, 2010 10:23 AM
89RS_82Z
Mar 22, 2008 05:31 PM
lonsal
Aftermarket Product Review
Feb 10, 2005 11:55 AM
