Tips on removing headlight motor if stuck down?
Old Jan 3, 2021 | 01:31 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
How do I remove the headlight motor if the gear is so far gone the manual crank won't work? I have a new complete motor for it. I just can't get it out because I can't get the headlight raised. Any suggestions?
Old Jan 3, 2021 | 01:43 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Tipa on removing headlight motor if stuck down?
Pull the entire headlight assembly out, or you can just try pulling up on the headlight door hard
Old Jan 3, 2021 | 02:34 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Re: Tips on removing headlight motor if stuck down?
I think the lever was just jammed up because the motor has been out for so long. I took too bolts out of the motor and wiggled it around and the lever loosened up and light raised up with my hand. New motor is in and good to go. All in all less than 30 minute job
LLCooLM495
Oct 8, 2020 09:37 PM
racerx520
Feb 11, 2008 05:13 PM
87_gta
Jul 27, 2007 11:16 AM
