How to take out console?
Old Jan 17, 2002 | 02:05 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Hello everyone! I have a 3rd gen Firebird and I am in the process of replacing my carpet, but can't get the center console out? Where are the bolts after to take it out without breaking it? I have an automatic, I took off the 2 screws in glove box and 2 by power window switch, and that is all the screws visible. Please help! Thanks... Andy
Old Jan 17, 2002 | 05:16 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
its pretty straight forward.
1) remove the 2 (7mm) screws on the plastic trim piece (under the front lip of the arm rest)
2) remove ash-tray and one (7mm) screw from under it.
3) gently remove the radio pod trim piece (pop's off)
4) remove the center console trim piece (pops off)
5) remove the light plug for the glove boc (center console)
6) remove the wires from the window switches & the power mirrors (If applicable)
7) twist to remove the little light holder for the gear shift indicator.
8) unplug your cig lighter
9) remove 3 10mm screws for the actual console 2 inside the glove compartment, 1 faces forward in the middle of the console.
Hope that helps
John
Old Jan 17, 2002 | 06:33 PM
Car: 1992 Formula
Axle/Gears: 3:42
Thank you very much! I got out the console tonight, I was on the formula source message board for a week and no answer and I am very happy I got help here after posting in less than 3 hours, thanks again! Andy
Old Jan 18, 2002 | 09:24 AM
okfoz's Avatar
Andy,
that is why I stick around here more than at the Formula source. I personally like the formula Source, but there are too few of people to really keep things going like around there...
glad I was of assistance.
John
Veaceonee
Sep 29, 2016 08:15 PM
Lbibb
May 5, 2016 12:00 AM
ndndndnd
Sep 28, 2015 08:00 AM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
