91-92 camaro hatch pull down motor problem
I have a 91 camaro rs and im having a problem with my hatch pull down motor. I have the plastic later modeled car. My pull down motor was working fine for years since i got it (probably the original components) few days ago chiped a couple teeth on the rise gear. Orded a new one off of hawks third gen. Installed the gear and now i cant figure out how to get the reverse switch to work correctly. Is there a special procedure? Help!
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: 91-92 camaro hatch pull down motor problem
I did this last year on my 92 z28. Check the connections.
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
The latch could be stuck in the down position, you can reset it by pushing it down with your finger. There are videos on youtube.
