1989 Firebird Door latch assembly
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 1989 Firebird Door latch assembly
The difference is mostly the counter sunk hole on the early doors, Vs flat on the later doors, but the latches appear to be the same. I bought these for my 84 and later transferred them to my 89.
https://www.ebay.com/itm/13303849806...QAAOSwEGxhL-Z~
Engine: 5.0 EFI
LH P/N for 88-91 is 16608069
LH P/N for 82-87 16608235
Well, changed the latch assembly today. Didnt fix the issue, it will unlock, but wont lock. The actuator isnt moving the rod at all when you try to lock it. I'm at a loss, any ideas, guys?
Engine: 5.0 EFI
Just a few questions,Does it lock with the Key?,does it lock moving the lock slide on the door?
Everything else works fine. At this point, everything in the door is new except the rods and they are in good shape, nothing bent or anything. Its got new lock cylinder, new outer door handle, new latch assembly, new actuator. The only thing I havent touched is the little thing that connects the actuator to the door lock rod. Its riveted in the door and cant find a new one anyway. Even when I move the actuator by hand, the actuator rod doesnt move the lock rod at all when you try to lock it.
Engine: 5.0 EFI
I was going to say maybe your rods are a little out of shape but you say their good,I'm curios about the actuator though,if it's not moving into the lock position it could be the actuator.I know you said it's new but sometimes they could be defective
