Anybody have tips on cleaning the hazed turn signal housings?
Old Jan 21, 2002 | 09:52 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
If not i was going to find some transparent testors orange enamel paint and use that. What do you think?
Old Jan 21, 2002 | 01:07 PM
Blue502's Avatar
Use Meguires plastic cleaner and polish, or else 3M Perfect-It to polish up the exterior. If the interior is really dirty, you just have to get in there with whatever you can, not easy. Turn signal lens housings are still available from the dealer. I'm not a fan of the orange paint idea, but hey, if that is what you like, might as well be different and go for it.
Old Jan 21, 2002 | 03:40 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
You could also use rubbing compound. Thats what I used and the lenses look brand new, cleans em right up.
Ted
Old Jan 21, 2002 | 03:52 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
if you have a paint and body supply house nearby-try getting some 3m brand stuff called "finesse-it" finishing material.it is made to final machine buff paint but if you use a soft towel by hand on the lenses with that stuff it turns out like new-as long as the damage on the lenses isnt thru the plastic
Old Jan 21, 2002 | 08:54 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanx guys.. i think i want to try to clean it before i paint it... have to look at 82-84s more to see if i like it orange...
Old Jan 22, 2002 | 01:38 AM
realslow85's Avatar
take the turn signal out of the car and put it in your bench vise, take some 2000 grit sandpaper and rough it up, then take the 3M machine glaze, for a buffer and apply it. then run a buffer over the lenses, and ta-freaking-da. brand new.
Old Jan 22, 2002 | 04:44 PM
Blue502's Avatar
That is what I use, but it has been replaced by 3M with the Perfect-It series product I recommended above.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
