Welding on Firebird
Old Sep 23, 2023 | 11:34 AM
mattfra's Avatar
Car: 1987 Firebird Formula
Engine: 5.0L
Welding on Firebird
So whoever owned my Formula before me ran the power windows up (without the door panel and weather stripping on) and the glass got caught on the screws that hold the outer belt line window weatherstrip on. Looks like it stressed/cracked a 2” section of the inner door. Window functions fine. I was looking to put a couple tack welds (MiG flux core) to keep it from getting worse. If I weld this I’ll disconnect the battery for sure. But what about the ECU? Or is it no different from getting an exhaust system welded? Thoughts?
Old Sep 23, 2023 | 02:01 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: Welding on Firebird
I would disconnect the battery, just as good standard practice.
Don't forget to "stop drill" the crack before welding.
Old Sep 23, 2023 | 02:28 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
You should be fine as long as you don't hit the wires with the welder. Make sure the welder ground is on the door very near the weld area. I would disconnect the wires and move them out of the way. I would also tack weld all along the crack like you would with a butt weld on a patch panel. Only a couple of tacks might encourage it to crack elsewhere along the existing crack with vibration over time.
Old Sep 23, 2023 | 03:59 PM
mattfra's Avatar
Engine: 5.0L
Excellent. Very good tips. I'll do those. Thanks!
soulbounder
Jun 14, 2020 12:03 PM
ken3983
Jun 28, 2006 04:50 PM
85z28cmro
Jun 24, 2003 11:38 PM
PAformula
Oct 2, 2001 09:04 AM
87 Firebird
Oct 21, 2000 01:19 AM
