Stopping Dash Vibrations
Old Jan 22, 2002 | 04:11 PM
shsdiver99's Avatar
Some one please help I have a 1984 pontiac firebird and when i go above 75 the whole dash starts to vibrate and rattle violently. What can I do to stop this?
Old Jan 23, 2002 | 03:43 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
dont drive over 75...........
its possible that some of the bolts/screws that hold the dash have came out (mine was missing bout half of them when i took the int out).. if u what to spend the time and effort, u could put blocking/padding behind the dash.
mike (loomdog)
Old Jan 23, 2002 | 03:52 AM
JPrevost's Avatar
Car: 91 Red Sled
You can do a few things. First I would try and secure the dash down with every possible screw. Next I would figure out why my car was vibrating so bad at 75mph. This is usually but not limited to; wheel alignment, old tires, stock steel driveshaft, and unbalanced tires (missing balancing clip or flat spot(s)).
Old Jan 23, 2002 | 10:18 AM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
I had the same problem on my 84 Bird. I replaced the steel driveshaft with an aluminum one. Now it's alot easier to speed cause the car doesn't feel like it's gonna fall apart anymore.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
