Cowl gasket
Old Jan 25, 2024 | 10:18 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Cowl gasket
I own a 1984 Trans AM. I know the gasket has failed over the years at the "cowl" on the hood. Part # 10030132 which is long gone. Would anyone have a picture of this gasket that they could post?
tkx
Old Jan 25, 2024 | 11:38 AM
codyman125's Avatar
Car: 1989 Firebird
Engine: 2.8 Liter V-6
Re: Cowl gasket
The closest thing to a picture I've seen is the diagram shown in this thread. Since we're back on the topic, as I said over there, if someone has one in just about any condition, I'd be interested in working to reproduce these.
@72buickgs If you've got some basic measurements, or remnants of the failed gasket, I can whip something up in CAD and try to make a prototype reproduction from TPU.
Old Jan 25, 2024 | 12:32 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Cowl gasket
I'm gonna need one...
Old Jan 25, 2024 | 01:02 PM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
If you've got any remnants of an original one, or can take some dimensions of where it is meant to fit (ideally both), I'd be happy to work on whipping up a prototype.
Might take a few attempts to get one that fits well, but these come up often enough that is seems worth some time.
Old Jan 27, 2024 | 11:15 AM
72buickgs's Avatar
Car: 1984 Trans AM
Re: Cowl gasket
Come spring I may remove the cowl & see what I have. Would I assume that the gasket is rubber?
Old Jan 28, 2024 | 05:09 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Cowl gasket
I have a NOS gasket for them. Its a thin closed cell type of foam. I think, been a while since i looked at it close
Old Jan 28, 2024 | 07:30 AM
72buickgs's Avatar
Car: 1984 Trans AM
Re: Cowl gasket
I would love to see a picture. Would u be willing to give Codyman a picture + dimensions. If u wanted to sell it, which I doubt, I would be willing to buy. Tkx
Gerry
Old Jan 29, 2024 | 09:12 AM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
I don't actually own the hood this would be needed for, so I don't need a good one. If you're willing to lend it out though, I could take some measurements and work towards making a reproduction out of a different material!
That said, dimensions would be better than nothing. If you can take pictures using orthographic and isometric views (as shown below) with a ruler set beside it, I can gather most dimensions digitally.
The best situation for me is to find someone who wants to install one and work with them on test fitting prototypes. (A 40 year old foam gasket probably isn't the most dimensionally accurate piece, so prototypes will likely be needed regardless.)
Old Jan 29, 2024 | 09:32 AM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
Purely speculation in this post, so don't take this as gospel.
An additively manufactured gasket produced from TPU could work for this sort of application since I can vary the infill % to match the stiffness provided by the foam.
I think this part is likely larger than the print bed I have available to me at home, but I may be able to prototype at work where I have access to a much larger printer. Production printing of these would need to be done outside of work though, so I'm probably on the hook for a new printer.
My largest concern with production of this part is the temperature that a hood will get to. TPU will start to get soft around 300F, and will start to melt closer to 350F. I think this is high enough to not be of concern, but on a 120F day in the Las Vegas sun in a black car with a hot-running engine under the hood, it might get dicey. Do you guys think that is a major concern?
Old Jan 30, 2024 | 09:29 AM
TTOP350's Avatar
Re: Cowl gasket
I should be in garage this afternoon and can get a picture.
its still somewhat soft. They really didn't last very long, most are dry and brittle pretty fast
Old Jan 30, 2024 | 12:54 PM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
That would be fantastic! Looking forward to seeing what you've got.
If reproduced from rubber, they should last substantially longer, but we'll see.
Old Jan 30, 2024 | 08:04 PM
TTOP350's Avatar
Re: Cowl gasket
sorry about the bad pictures but the gasket still hasn't flatened out
Old Jan 30, 2024 | 10:40 PM
72buickgs's Avatar
Car: 1984 Trans AM
Re: Cowl gasket
Great!
Old Jan 31, 2024 | 08:20 AM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
It really is just a plain flat gasket. I didn't expect that from the GM diagram. I'll see what I can whip up as a template, and probably switch to just cutting it from a sheet.
Old Jan 31, 2024 | 08:31 AM
TTOP350's Avatar
Re: Cowl gasket
Im sure it was die stamped from a sheet roll like the hvac foam gasket parts were. It does have the sticky side and is all 1 piece.
Old Feb 12, 2024 | 01:05 PM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
Just stopping by to say this is still on my radar. I get married in 18 days, so this hasn't been priority number one just yet.
Old Mar 8, 2024 | 07:38 PM
T.L.'s Avatar
Re: Cowl gasket
So the offerings from the after-market aren't any good?...
Old Mar 12, 2024 | 06:47 AM
TTOP350's Avatar
Re: Cowl gasket
What offerings? Can't say ive ever seen it
Old Mar 12, 2024 | 09:04 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Cowl gasket
I know a guy who makes these sorts of gaskets and seals, but I just don't know if there's enough volume for a piece like this to interest him or not.
Old Mar 13, 2024 | 11:24 AM
TTOP350's Avatar
Re: Cowl gasket
How many would it take to interest him?
Old Mar 14, 2024 | 08:49 PM
DynoDave43's Avatar
Re: Cowl gasket
I don't know. I'll look him up and ask.
Old Mar 20, 2024 | 08:04 PM
T.L.'s Avatar
Re: Cowl gasket
Such as this?...
https://www.summitracing.com/parts/mmp-cs15-a
Old Mar 20, 2024 | 08:56 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Cowl gasket
the gasket in the Summit link is for the rear hood to cowl. the piece they're discussing is the gasket that goes under the hood bulge insert - circled in red below
Old Mar 20, 2024 | 09:09 PM
codyman125's Avatar
Car: 1989 Firebird
Re: Cowl gasket
@TTOP350 I had a revelation today while looking at this gasket. Do you have a flat bed scanner or scanner/printer combo? That would make getting the dimensions laughably easy. Just scan the gasket with a ruler on there too.
(helps to get my comment in the right thread… whoops)
Old Mar 20, 2024 | 10:01 PM
battmann's Avatar
Re: Cowl gasket
Instead of trying to get the gasket to lay flat and straight it would probably be easier to just measure the bottom surface of the hood insert.
82tarecaro
Mar 20, 2024 08:58 PM
cooltc2004
Apr 21, 2005 04:27 PM
