can anyone help with a underbody measurement
Old Feb 9, 2024 | 12:51 PM
386kustoms's Avatar
Car: 1983 daytona pace car
Engine: crossfire
Transmission: world class 5 speed
hey guys, i got the specs for the underbody measurements on these cars but i need to know something that they do not show. i stole this picture off of here so i hope its ok. the front red lines are pointing to the bolt on the k member, the rear red lines are on a frame hole. don't worry about the middle lines. anyway is the measurement the exact same from front k member bolt to rear frame hole on each side or is there a difference. i didn't know if someone has a tram gauge and there car up in the air and could see if the measurements are same left to right
Old Feb 17, 2024 | 02:29 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: can anyone help with a underbody measurement
I might be able to help with the measurement in the center and in the back. My front suspension is still in place so I don't think I can measure that one. I don't know if I can measure to the +/- 3 mm requirement though. I am out of town right now but can check on Monday or Tuesday.
Old Feb 20, 2024 | 12:38 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
My measurements match what is on the factory drawing that you show in your message. However, I notice that at the center measurement you are indicating with your lines a difference set of holes than where the factory measurement is taken. I will need to get back under my car tomorrow and measure the holes you are indicating in the subframe next to your subframe connectors and double check the ones in the rear (right side in the drawing).
UNCLE TOM
Fabrication
20
Nov 3, 2013 10:30 PM
87350IROC
Brakes
Jun 7, 2010 11:37 AM
1bdbrd
Aug 26, 2009 01:08 PM
geoffz28
Brakes
Apr 1, 2009 06:41 PM
MechCD
Aftermarket Product Review
May 5, 2005 10:09 AM
