Axle Hard Lines?
Old Feb 26, 2009 | 10:16 PM
geoffz28's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Moser 12bolt 4.10s
Axle Hard Lines?
Im putting in a 9bolt disc brake rear with the 11.65" rotors . I dont have the axle hard lines. Just wondering if anyone knows the correct lengths/fitting/flare for the the right and left side. Thanks
Geoff
Old Feb 27, 2009 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Axle Hard Lines?
Sorry, I don't know the particulars. IIRC, I purchased new from http://www.finelinesinc.com/
JamesC
Old Feb 27, 2009 | 07:12 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
They are bubble flair ended lines. The tool to do the flairs is espensive (around 70 i heard) so instead i bought some straight lines around the same lenth that i would need from napa with the flairs and fittings already on em for a few bucks and bent them to the shape i needed. As far as what the actual fitting is i cant remember. I believe its metric though.
Old Mar 31, 2009 | 12:22 AM
bigals87z28's Avatar
Car: Check The Sig
Anyone know which ones you would need? I dont know what year the rear came out of, but its a 9 bolt rear with PBR calipers. I want to put it all together, but am missing some brake lines like the OP. Anyone have any ideas?
Old Mar 31, 2009 | 06:25 AM
JamesC's Avatar
There's no difference between 9- and 10-bolt lines. Check post #3 of the following link for a part #:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Mar 31, 2009 | 11:08 PM
Car: Check The Sig
I figured it out, and orderd the 89-91 J65 rear disk brake lines.
Old Apr 1, 2009 | 06:41 PM
vorteciroc's Avatar
Top Answer: 1
Geoff
The axle hard lines are 3/16" and the tube nuts are M10 x 1.0 Bubble flare
Matt86IROC
Sep 7, 2015 06:30 PM
gixxer92
Sep 1, 2015 04:32 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
