Heat Shields
Old May 18, 2024 | 08:18 PM
brando278705's Avatar
Car: 1987 Camaro IROC-Z
Engine: 5.7
Axle/Gears: 3.70
Heat Shields
Hello! Tried Searching the forum for some advice, couldn't find it. What is everyone's thoughts/opinions on the underbody heat shields. I have my rear end out right now and and working on getting it back in. My heat shields are a bit dirty and has top rust on a few spots. Do you powder coat these things? Just bead blast? Or just leave alone and reinstall!?
Old May 18, 2024 | 10:09 PM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
Re: Heat Shields
I took a wire wheel to my heat shields then used high temp aluminum paint.
Old May 18, 2024 | 10:22 PM
Engine: 5.7
Axle/Gears: 3.70
Re: Heat Shields
Those look really great!
Old May 21, 2024 | 08:38 AM
Engine: 5.7
Axle/Gears: 3.70
Re: Heat Shields
Here's an update. I used VHT Flat Aluminum spray after I wire wheeled them. Will get them on soon!
Old May 21, 2024 | 10:55 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Heat Shields
I had mine powdercoated. I probably would have used high temp paint but I dropped them off with all the other stuff I was getting coated at the time.
Old May 21, 2024 | 05:38 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Heat Shields
High temp ceramic coating is a good option
MisterCrowley
Jul 10, 2022 01:37 PM
L0tuS
Jan 5, 2022 06:54 PM
hardcoreZcar
Jun 13, 2017 05:47 PM
Destro Camaro
Feb 26, 2017 10:51 PM
slowfast
Aug 14, 2006 09:13 PM
