Weather Strip Channel and Drip Rail Tape?
Car: 92 RS
Engine: 3.1 V6
So, I pulled the window weather strip off (92 Camaro) and then removed the screws for the weather strip channel. I found it had a rubber like double back tape the full length of the channel which appears to form a seal. I heated that and gently pulled the channel down and out. I then found the drip rail has about 4 tabs that also use a thin double back rubber like tape to hold it in place. I carefully heated those and pulled the drip rail down and out. I have a little surface rust to clean up and repaint under the channel and drip rail before I put it back together. Anybody have a recommendation for new double back tape for both pieces to reinstall them?
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Weather Strip Channel and Drip Rail Tape?
Hawks motorsports or similar restoration place
3M tape.... You can find it at most parts stores like AutoZone... I use it for the channels, emblems, etc.... strong stuff ...
CAlled 3M Molding tape....
Car: 92 RS
Engine: 3.1 V6
Other than 3M tape, this is the only tape I have found advertised for the specific application:
https://www.camarocentral.com/1967_1..._p/wea-199.htm
With the 3M tape I am concerned that it is a bit too thick. With the Camaro Central tape, it says it is only 1/16 inch thick so should be ok from that standpoint but I am concerned whether it will keep the water out since it says it is a foam tape where as the original looks like solid rubber. It is also 3/4 inch wide but the original on my car was 1 inch wide.
