Smoothing Firewall Weld Opinions?
Car: 92 RS
Engine: 3.1 V6
I had to replace parts of my firewall around where the heater box mounts. My old welder did not do a very good job so, although I have ground the welds down, the surface on the inside of the firewall is a bit rough where the gasket for the heater box sits against it. The original gasket seems to be in pretty good shape. Should I use body filler or just seam sealer to smooth the surface where the gasket sits?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Smoothing Firewall Weld Opinions?
You're going to want to add tack welds to the seems that run along the firewall or any body work may crack. There is a lot of flex there.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
