Can I put a 90s camaro rocker panels on my 86 camaro?
Old Jan 2, 2026 | 05:59 PM
Calyps0's Avatar
Car: 1986 iroc z
Engine: 305 tpi 5.0L v8 F Vin
Axle/Gears: Stock?
I recently messed up my rocker panel on my car (top photo, before destruction) and i like the style of the 90s models with the small tunnel. Im wondering how interchangeable they are...thank you
Old Jan 3, 2026 | 11:56 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Can I put a 90s camaro rocker panels on my 86 camaro?
I couldn't say if they're a direct swap or how they attach, but a lot of people have done it, so it's apparently doable. Some 85-90 Trans Ams have even swapped to the 91-92 Camaro rocker GFX. The "vents" are a good look. And now that you've gotten a reply, people will start replying lol.
Old Jan 4, 2026 | 09:41 AM
Calyps0's Avatar
Car: 1986 iroc z
Axle/Gears: Stock?
yeah, Ifigured id have to drill holes for new brackets, im hoping there is a guide somewhere out there lol
Old Jan 8, 2026 | 05:49 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
The biggest difference is where and how they attach to the front fender. The '85-'90 rocker panel attaches with a pair of long sheet metal screws that are hidden behind the emblem. The '91-'92 rocker panel has a couple mounting studs instead.
The next biggest difference is at the rear quarter panel attachment point. Both styles use a mounting stud (except the '85 model, iirc), but the location of the stud was raised higher up on the '91-'92 rocker panel.
The '91-'92 panel has an additional mounting screw along the door jamb area, compared to the '85-'90 rocker panel. Iirc, the '85-'90 support brackets do have provisions for that additional screw however.
The screw locations along the bottom of the rocker panel appear to be all the same.
johnblacksox
Feb 17, 2024 08:56 PM
NastyL98_T/A
Mar 17, 2004 04:42 AM
sittincamaro
Dec 1, 2003 05:21 PM
