What year guages are a direct bolt in for 86 IROCZ??
Old Feb 6, 2002 | 11:18 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
Mines ****ed up so Iam going to the junkyard ina few weeks when I get my first paycheck with my new job to see what they have,they have several thirdgen camaros there last time I was there,so what years guages(I am replacing all of them) would be a direct bolt in with an 86??I think any82-90 would work,correct me if I am wrong,I am looking for either a 15 speedo or a 145 spedo and I am not paying $75-100 for one either thats why i am going to the junkyard
Old Feb 6, 2002 | 11:22 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
82-89.. the clusters changed in maros in 90.
mike (loomdog)
Old Feb 7, 2002 | 01:36 AM
Blue502's Avatar
To find the speedo you want, you need to find a late '86-'89 for your donor.
Old Feb 7, 2002 | 03:01 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Yup 86-89.
Or you could upgrade to 90-92, if your up for the challenge...
Old Feb 7, 2002 | 11:46 PM
prepz28's Avatar
i have an 86 IROC. I swapped out my entire cluster for one out of an 85 Z-28.
Old Feb 8, 2002 | 10:29 PM
Blue502's Avatar
Thats fine if all you want is the original 85mph speedo, they are the same. But if you want to upgrade to the higher speed ones, you need the years I specified above.
Old Feb 10, 2002 | 06:55 PM
toosloz's Avatar
nope...you guys need to look at this with alittle more thinking....an 89 will NOT work due to the plastic/coppoer wire strip in back.....i have tried installing a 89 rs cluster in my 84 and everything went haywire...i think it may have to do with the vats system or just a totally different wiring set up
but, you CAN switch the gauges from a newer cluster to an old cluster...thats works...i have a voltage guage from a 89 rs in my 84...
what gauage is messed up?.....its less work to change the guage then pulling the whole cluster...you got a/c?...have fun, its tight!
if just the guage is messed up it will take a 5mm socket and 10 minutes time to be back on track
Ghettobird52
Jul 5, 2024 11:18 PM
IBrockZ
Aug 20, 2015 12:20 PM
355sbcTPI
Aug 19, 2015 04:38 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
