How hard to replace the galss in the side view mirrors?
Old Feb 6, 2002 | 03:16 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
How hard is it to replace the galss in the side view mirrors? I will get the glass from the bone yard if it is easy.
Old Feb 6, 2002 | 04:26 PM
genyuschrist's Avatar
Im not sure about third gen mirrors, but i know some you cant just replace the glass...So you might wanna just get the whole mirror, like i said though, not sure.
Old Feb 6, 2002 | 04:40 PM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
ttt
can anyone answer the question
Old Feb 6, 2002 | 04:56 PM
smurfmobile's Avatar
well I'm not so sure about normal mirros , but with power mirrors you can just unsrew the 3 screws that hold it to the metal (they are underneath the mirror . I forget how you do it , but I Think you have to pry away the glass and then push on a new one (it's held by these weird X joints or whatever they are) ,lol
so it's definitely possible on power mirrors
Old Feb 6, 2002 | 05:52 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
If you try and pop the glass out you will break it trust me i know your best bet is to just replace the whole mirror it will save you some time good luck dave.
Old Feb 6, 2002 | 08:57 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
First off, yes you CAN replace just the galss on any of the mirrors (manual or electric). Be aware there are two styles of electric mirror. The older style has a screw in the center under the glass attaching it to the motor. On that style you HAVE to break the glass to remove the plastic backing piece from the motor. The newer style has a cross shaped metal piece that can be pried from the plastic retainers holding it to the motor. Either style, try removing the glass with a putty knife. Wear safety glasses and gloves when doing so. You will likely break the glass to remove it. Replacement mirrors are available at Pep Boys and other auto parts stores for a lot less than from the dealer. The drivers side is indistinguishable from OEM. I found the passenger side lettering "objects in the mirror..." looked a bit fuzzier than OEM. They have double sided tape that you peel the backing and apply. You can also use silicone or weatherstrip adhesive cement to attach it better. Good luck, Lon.
Old Feb 6, 2002 | 09:09 PM
Nightcruzer's Avatar
Car: Trans Am
I'll second what Ionsal said. You can just replace the glass, I have done it. I got mine, fit perfect, and even says "obects in mirror..." for total with shipping of $24.95. Yes I could have bought a whole new mirror w/housing cheaper at a junkyard, but I have custom paint on the mirror housing, I didn't need to go to a junk yard and I didn't break a sweat. The replacement mirror glass just glues back on with silicon adhesive sealant, just like the original. The website for the mirror is www.automirrors.net or www.nationsglass.com They are the same company. I didn't see mine listed, but just e-mailed 'em and I had my replacement in under 5 business days.
Old Feb 6, 2002 | 10:09 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanx, ill try that
right now on my drivers side i have this replacment glass from supertrack that goes on top of the old glass with double sided tape. Cost me a couple bucks and is very cheap.
Old Apr 17, 2017 | 05:18 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Re: How hard to replace the galss in the side view mirrors?
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Omega
Exterior Parts for Sale
Aug 10, 2015 10:19 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
