4th gen ac/heater in 3rd gen possible?
Old Feb 23, 2002 | 09:23 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Is it possible to put 4th gen heater/ac controls in a third gen with a custom center console.
Old Feb 24, 2002 | 06:16 AM
FiReBReTHa's Avatar
then you may replace the AC and heater core so you can do soemthing with that funky 4th gen Acheater controls...
4th, electric.
3rd cable.
Old Feb 25, 2002 | 06:21 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
the 3rd gens hvac controls are comtrolled by vaccum lines.. the temp control and and postiion selcetion (vent, floor, defroster).. u have to convert those to electric & get a new heater core (thats what i know u have to change, theres probably more tho).. if u know/find out how to convert these please inform us.. the blower is electric (ie: low, med high)..
mike (loomdog)
Old Feb 28, 2002 | 01:42 AM
91L98Z28's Avatar
Car: Z28
*wondering out loud*
pontiac fiero has an almost identical design heater/ac panel, except it's all pushbutton/electrical (fiero uses motors to control the heater box). don't know if gm used this anywhere else.
wonder if this panel could be used to control electrically-operated vacuum solenoids? might take a bit of wiring work, and I don't know if compact, electrically-operated vacuum solenoids are available, but the panel should fit in the camaro, and they are so much nicer to use, you just push the button, no more sliding the silly slider back and forth to make sure it's in just the right position.
that way the heater box and all it's vacuum canisters stay in place and it's less of a mod. it still isn't the fourth gen full **** style, but way better than the stupid slider.
Old Feb 28, 2002 | 02:58 AM
loomdog32's Avatar
Car: 82 Camaro Z28
is the hvac conrols on the fiero vaccum or electronic?? if there vaccum, then it SHOULD plug in, probably with some modifications.. easiest way to tell is to look at the back of one.. if there are bout 7-10 nipples (for vaccum lines) then its vaccum controlled.. if not and there is just a wiring harness then its electric.. hope that helps the thought in ur head along......
mike (loomdog)
Old Feb 28, 2002 | 11:35 AM
91L98Z28's Avatar
Car: Z28
I own a fiero so i can vouch for the fact that it is a pure electric panel. the fiero heater box is fully electral motor activated.
that's why you'd have to have vacuum solenoids...so that when you push the pushbuttons, the solenoids activate and route the vacuum appropriately.
i don't know how the hot/cold slider would work though
Old Mar 1, 2002 | 05:56 AM
loomdog32's Avatar
Car: 82 Camaro Z28
hmmm.. y cant ur cars have electric hvac controls?!?!?!?!?!?!? dammit... it would make things like this alot easier.. oh well... i would like to see the swap done.. so i have a true template for when i attempt it..
mike (loomdog)
Old Mar 1, 2002 | 07:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
GTAs with a digital dash have a fully electric panel too. Possibly the same one as the Fiero.
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
