Has anyone used their console for mounting switches??
Old Feb 27, 2002 | 12:27 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
Does anyone have pics of their console with switches mounted on it? (for example, nitrous, torque converter lockup, etc.) thanks,
-dave-
Old Feb 27, 2002 | 01:12 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My buddy has 4 switches on his console for his old Nitrous setup he used to have in his 86 Z. I'll see if I can get pics of it this week for you. Switches look stock too.
Old Feb 27, 2002 | 01:41 PM
bradkeith's Avatar
dave, i mounted my switches in the slant of the dash right above the climate controls. they look really good there. Probably not what you want to do, but i thought i'd give you a pic so you could see.
Attached Thumbnails Has anyone used their console for mounting switches??-img-023-3.jpg
Old Feb 27, 2002 | 02:27 PM
Engine: 350 CID
bradkeith that looks cool as....heck. lol. I would do that, but I already fell in love with the :hail: aircraft-style flip switch. Was it hard to wire the switches and lights in? If the switches Im getting fit in the slant I might put them there, or ill just get one of the switches you have and use it for my torque converter lockup switch.
Old Feb 27, 2002 | 02:50 PM
un4givin89's Avatar
Once apon a time I did, but everyone made fun of me
Old Feb 27, 2002 | 08:50 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Ive got 4 mounted on a plate where the ashtray was.
Andrew
Old Feb 27, 2002 | 10:20 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I have my fan switch and TC lock up switch right above the heater controls.
Attached Thumbnails Has anyone used their console for mounting switches??-tainterior.jpg
Old Feb 27, 2002 | 10:48 PM
GTA400SBC's Avatar
I took out the lighter and mounted a swtich in that little hole for my fan I also made an alluminum plate that goes in place of the ash tray and mounter a starter button
Old Feb 28, 2002 | 10:32 AM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
No4NJunk
On that picture you posted, it looks like your radar detector cable is comming out of your dash.. Is this true? If so, how did you wire this? I'm interested in wiring it so my radar detector is connected to a switch on my dash or console... Easy to turn on / off (rather than plugging un-plugging) and also gets the cable out of the way. What did you plug the cable into???
Old Feb 28, 2002 | 10:53 AM
bradkeith's Avatar
Supercharged 84z.. The switches were easy to wire up and install. The hardest part was snaking my hand up behind the dash to hold the switchs still while i tightened the nut on them. The switches i used were double pole, single throw. I got them at radio-shack 1.99 for both. The lights were also 1.99 for 2. I wired the switches into the hot side of the circuits, and then ran my hot light wire from the switch, and grounded the other side to my dash.
Old Feb 28, 2002 | 11:00 AM
Engine: 350 CID
considering nobody is going to smoke in my car unless the t tops are off and the windows are wide open at 70mph, the switches in the ashtray idea is kinda cool....i just have some thinking ahead of me...the pics help alot, thanks.
-dave-
Old Feb 28, 2002 | 12:18 PM
No4NJunk's Avatar
Trans Am
It is coming out of the dash. What I did was take the cigarette lighter out of the console piece and stuck it underneath the whole center console. If you don't do this then the radar plug will stick up and you'll have to leave that door open. Then I ran the wire up behind the stereo and through the grey part of the dash. and whala! The on/off switch is on my radar so I just turn it on by that.
Old Feb 28, 2002 | 01:28 PM
GTA400SBC's Avatar
I wired my radar right to the fuse block. i cut the lighter thing off and spiced on to an Acc. wire and it comes on when i turn the key on. I ran the wire down the driver side pillar and down to the fuse block, its mounted on my sun visior. nice and clean you can't see any wires
Old Feb 28, 2002 | 01:30 PM
Engine: 350 CID
GTA do you have any pics?
TransAm's Avatar
Hmm. That's more a long the lines of what I was thinking... Wiring it up along the pillar or thru the dash (whether i put it high or low) and splice it on... also splice in a switch so i can easily turn it on and off w/out actually touching the detector (kinda a pain when driving standard @ the same time)
Anyone else done this?
Old Feb 28, 2002 | 07:13 PM
Jim's Avatar
Jim
Car: 85 Camaro
Mine is set up that way too, but instead of the center of the dash I sat mine beside the A-piller. Nothing is more annoying than the cops following you with the radar gun wide open so they can see a light show. It has been there like that for three years without a problem.
Old Feb 28, 2002 | 07:26 PM
TransAm's Avatar
Jim or GTA400SBC do you have any pics of your radar setups?
Old Feb 28, 2002 | 07:44 PM
Jim's Avatar
Jim
Car: 85 Camaro
Here you go. I will get a better pic Tomarrow when the sun is out.
Attached Thumbnails Has anyone used their console for mounting switches??-dash.jpg
Old Feb 28, 2002 | 09:01 PM
Jim's Avatar
Jim
Car: 85 Camaro
Here's a better one, please exuse my dust
Old Feb 28, 2002 | 09:02 PM
Jim's Avatar
Jim
Car: 85 Camaro
Here's a better one, please excuse my dust
Attached Thumbnails Has anyone used their console for mounting switches??-dash2.jpg
Old Feb 28, 2002 | 09:05 PM
TransAm's Avatar
*dust excused* hehe.
Looks pretty cool. So did you run the power line actually under the dash or did you just do it along the side of the dash so it's out of view? Did you mean that you wired it to the fuses as well? Or are you still connected thru a cigarette lighter?
Old Feb 28, 2002 | 10:19 PM
Jim's Avatar
Jim
Car: 85 Camaro
Right now I am using the cigarette lighter, I wiil be running a direct link to the accessory slot in the fuse box again when I get a chance to call whistler and order one. I never got around to it when I upgraded detectors. I usually hook up to the accessory slot in the fuse box so that the radar detector turns on and off with the ignition switch.
Old Mar 2, 2002 | 11:46 AM
BirdonFire's Avatar
I have my detector mounted high, just below my rear view mirror. I have it hard wired into my overhead console. You know the little switch that turns on your dome lamp? (never used it) I disconnected it and wired my detector to it. I can either have it automatically turn on when the switch is on or I can have it turned on when ever I like.
Old Mar 2, 2002 | 12:08 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
In the directions for my radar detector, it says its best to mount it low, right on the dash in the center. Jim: Does yours have any problems mounted all the way in the corner like that?
Old Mar 2, 2002 | 09:06 PM
Jim's Avatar
Jim
Car: 85 Camaro
absolutely no problems what-so-ever
Old Mar 3, 2002 | 12:55 AM
mattRS's Avatar
i have my manual fan switch mounted in the plastic right underneath my e-brake. the switch is barely an inch tall, so clearance isnt a problem at all. my friend had his nitrous switch actually IN the ashtray, so the lid could flip down and conceal it.
bradkeith:SMOOTH install. i like that a LOT man.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
TheJoeY88
Aug 13, 2015 06:51 PM
