Convert manual windows to power
Old Mar 9, 2002 | 08:16 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Is there a way of converting manual windows to power windows, with out having to replace the whole arm mech. is there a way of just taking the handle out and installing a motor in the door that goes in the same place? granted some fabricating may be required.
Old Mar 9, 2002 | 09:13 PM
2vmodular's Avatar
Old Mar 9, 2002 | 10:40 PM
Car: 89 Camaro RS
Engine: 305 TBI
Hey right on.. thanks man..
Old Mar 10, 2002 | 09:37 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
may i suggest what i'm doing:
used doors plus wiring harness
Old Mar 10, 2002 | 10:25 PM
Car: 89 Camaro RS
Engine: 305 TBI
Out here the pick your own part source has nothing but crap.. and the ones that pick it for you want an arm and a leg for the parts..
Old Mar 10, 2002 | 10:33 PM
Car: 86 Z28
Axle/Gears: TBD
sorry to hear
Old Sep 16, 2002 | 01:51 PM
FLYNLOW92rs's Avatar
Bringing it back from the dead
2vmodular, How long did it take you to install the power windows and how was the total cost of installing the windows (parts, kit, etc)
Old Sep 16, 2002 | 02:37 PM
2vmodular's Avatar
Re: Bringing it back from the dead
should be able to get everything you need for the project for under $200.
a step by step guide to retrofitting power windows is avaliable at:
http://www.p71interceptor.com/thirdgen/powerwindows
Old Sep 16, 2002 | 02:42 PM
2vmodular's Avatar
a guide to adding powerlocks to your ride is avaliable at:
http://www.p71interceptor.com/thirdgen/powerlocks
Old Sep 16, 2002 | 06:47 PM
PopaPork's Avatar
I did the manual power swap this summer. I got everything for 70 bucks, the switches the motors and the wiring. I dont know if I would call it easy though. The first one took me all of a saturday, but that included gettin the console out, puttin in the switches and running the wires, and removing the old crank motor and gettin in the new one. I'd have to say the hardest part is puttin in the bolts to hold that thing up. There isnt much room in there to get your hand. I had to have my buddy hold the window and move it around so I could get my fingers in the right spots to put in the bolts. It was a real PITA. BUUUT they work great now. I recomend if you do it, plan on doing it for a few days, and get some grease and grease up the tracks and stuff. Also get some help, I talked to a guy who did it himself and he said it was a real pain, Thank *** for Jim86bird, JPrevost, and ZNutter....
If ya need help let me know....
Old Sep 16, 2002 | 07:11 PM
Saywhut's Avatar
Talk with Dal Slabaugh at Vandevere Olds
Old Sep 18, 2002 | 12:39 AM
eighty2z28's Avatar
When I first bought my z it had a conversion that consisted of a little "box" that was mounted over the original shaft coming out of the door for the crank windows one on each side in the box was a motor that turned the shaft they worked great but I have since put new doors on which had factory power windows. has anyone else seen these. I am wondering if they are still available and who origannaly made them....
Old Sep 18, 2002 | 10:09 AM
PopaPork's Avatar
I think JCWhittney sells something like that, The Universal Power windows kit....
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
