part numbers for 91-92 z28 tail lights?
Old Mar 25, 2002 | 11:50 PM
Kandied91z's Avatar
anyone...........
i'm looking to find the part numbers for the left and right tail lights. any help would be appreciated.
Attached Thumbnails part numbers for 91-92 z28 tail lights?-superfest-tail-end-modified.jpg
Old Mar 27, 2002 | 12:05 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Lens, RR comb LP LH: 5973749
Lens, RR comb LP RH: 5973750
Lon
Old Mar 27, 2002 | 02:01 AM
Kandied91z's Avatar
is that for the whole tail light?
also, i forgot what year these tail lights started. anyone know what year they were implicated?
thanks ion
jeff
Old Mar 27, 2002 | 03:21 AM
Blackened's Avatar
They started in 85 with IROC and Z28.
Old Mar 27, 2002 | 08:27 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
thanks ion
jeff
85-87 iroc and z28
88-90 iroc
91-92, all camaros.
Old Mar 27, 2002 | 08:54 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
As far as the lenses the same part number applies for:
85-92 Z28, IROC Z-Model and 91-92 RS Model.
Right Rear Combination Lamp Lens
GM Part # 16503488 $189.00
Left Rear Combination Lamp Lens
GM Part # 16503487 $189.00
Old Mar 27, 2002 | 09:36 PM
Kandied91z's Avatar
why are the part numbers different from above mike, anyone know?
anyone use gmpartsdirect? they list the parts much cheaper. can anyone order from it and how is the service?
according to ions part # they are 88.26 each, although the part is listed as lens asm whatever that means.
mike your part is listed as just lens and they want 115.80 each.
i want the whole tailight, which part is the one i want? what is the difference between the two?
Old Mar 27, 2002 | 10:09 PM
91rsrider's Avatar
hey kandied yes anyone can order from gmpartsdirect.com. the prices on there are the same employee prices that i can get at the Olds dealership i work at,only i dont have to pay the shipping.im sure their service is good,since you are dealing with GM directly from their warehouses.
Old Mar 28, 2002 | 10:37 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
The part numbers I pulled for you are from the Mitchell Collision Estimating Software. This is the program we would use if someone came in with the rear end crunched and needed new tail lights.
The asm means assembly. When I try to pull up "combination lamp and lens assembly" it specifies "Order from Dealer" because some complete assemblies are no longer available or have been cross referenced to another part so I gave you just the lens price.
But what you want to ask your local GM Dealer for is the:
Combination Lamp and Lens Assembly
Also: the Mitchell program is pretty accurate and is updated monthly however it could have a part number mistake. And when you check different places and get different prices make sure they are not subbing "aftermarket parts".
Old Mar 28, 2002 | 05:54 PM
Kandied91z's Avatar
thanks everyone i appreciate it.......if everyone can use it i wonder why they don't. i certainly wouldn't want to pay 200 a light when i can get it there for 100.
o'well works for me. thanks again.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
