what are the best replacement calipers?
Old Feb 9, 2012 | 06:48 PM
Project-RS's Avatar
im looking to upgrade my front brakes, but on a budget. anyone know which calipers are best without changing my factory spindles?
Old Feb 9, 2012 | 06:50 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: what are the best replacement calipers?
ive never heard of any that will bolt on without modification but i did find this http://lukeskaff.com/?page_id=329 would be pretty cheap if you can do the work yourself
Old Feb 9, 2012 | 07:31 PM
Project-RS's Avatar
i know i can upgrade the rotors to drilled and slotted. if theres a better caliper thats a stock replacement, i rather buy that also
Old Feb 9, 2012 | 09:29 PM
Car: 1990 camaro RS
Engine: 305 TBI
the link i posted was for converting to LS1, and corvette brakes not just drilled/slotted
Old Feb 11, 2012 | 12:25 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
ssbc makes a quick change caliper kit for the front brakes. Its a light weight 2 piston caliper. I think its around 450 bucks
Old Feb 11, 2012 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd do a search on those replacements before I dove in. For example, check the following post:
https://www.thirdgen.org/forums/brak...-calipers.html
JamesC
Old Feb 11, 2012 | 07:19 AM
Project-RS's Avatar
i tried doing a quick search for the parts needed for the c4 and other conversions. anyone know how much it roughly costs to do it?
Old Feb 11, 2012 | 07:27 AM
JamesC's Avatar
The company below makes many kits (though I'm not sure that the budget minded will be impressed):
http://www.flynbye.com/
JamesC
Old Feb 11, 2012 | 07:31 AM
Project-RS's Avatar
wish i had the 1000 for the ss conversion
Old Feb 11, 2012 | 01:22 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Quick search found this.. a bolt in for your stock spindle.. wont improve your rotor size but will shed some weight..
http://www.wilwood.com/Calipers/Cali...ingle%20Piston
http://www.daymotorsports.com/pop.ph...ic-Caliper.jpg
Old Feb 12, 2012 | 10:50 PM
Car: 1990 camaro RS
Engine: 305 TBI
i got drilled slotted rotors and calipers off a 02 camaro that had 77k on it today for right at 50 bucks from the junkyard, like new rotors too.
Old Feb 13, 2012 | 06:46 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you can do some of the work yourself, you can save a lot of money on the SS swap. I paid about $60/ea for my rebuilt calipers, $75 for brackets, and about $90 to have the hubs turned (some have paid as little as $50, so search your local machine shops). I did my own cutting on the spindles, along with my own drilling and tapping for the new hardware. In total, I think I've got about $500 tops from start to finish into my front brake swap.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
