brake rotor choices???
Old May 16, 2003 | 02:05 AM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
I just got me a 89 IROC and i need to replace all the rotors on it... i was wondering what would be a good set to use??
It has 4 wheel discs.
Old May 16, 2003 | 02:14 AM
Kandied91z's Avatar
gm makes a set if you want to go custom or most auto parts stores will carry many different versions. just depends on the budget.
Old May 16, 2003 | 11:36 PM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
I plan to get into autocrossing..i was thinkin cross drilled and slotted, do they make these??
Old May 17, 2003 | 02:17 PM
Kandied91z's Avatar
sure.........
Old May 17, 2003 | 02:18 PM
Kandied91z's Avatar
or the new ones........just depends on your budget.
Attached Thumbnails brake rotor choices???-jeffs-baer-brakes-behind
Old May 17, 2003 | 06:14 PM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
id say the first pic. what are they where did you get them? and how much??
Old May 17, 2003 | 06:19 PM
Kandied91z's Avatar
they are made by gm and are very high quality but expensive.
there are a few aftermarket companies that make similar setups however they tend to be alittle thinner and cause cracking when overheated.
the gm versions were roughly 650 for all 4. i currently have the fronts with braided line for 200 plus shipping if your interested. otherwise i believe you can get the cheaper aftermarket versions anywhere from 100-400 for a set depending on the options.
good luck.
Old May 17, 2003 | 06:22 PM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
Email me at SoullessSiR@hotmail.com and i will see if i can get those brakes from you.
Old May 17, 2003 | 08:47 PM
jaminJimB4C's Avatar
Car: 1991 RS B4C
Engine: Stock 350
Hey Kandied91z, I dig the wheels. Where did you get the spacers to use them?
Old May 18, 2003 | 02:03 AM
Kandied91z's Avatar
skulte..........same as the many others on the board. thanks for the comments.
Soulless, just email me if your interested. i get alot of bites but most fall through. the braided lines are made be earl's. sell for 98 through summit for the whole kit and the rotors are a little over 150 a piece new. the lines have about 500 miles and the rotors have somewhere around 2500. the rotors in the picture are only a week old...........the difference is in the coating. the eradispeed baer's have zinc to keep them nice where as the gm don't. however the baer's are around 280 a rotor. all of it is in great shape but i do like to drive my car when it's nice. let me know.
Old May 18, 2003 | 10:52 PM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
i need your email, and do you have the part numbers for the GM rotors?? i wanna check them out...
Old May 19, 2003 | 04:01 PM
Kandied91z's Avatar
i believe this is the number for the fronts.
18038517 18038518
the list price on my receipt is 270 however i paid roughly 150 and i've seen them on the net for even less however in most cases with shipping it equals out.
if your interested let me know, also if you don't want the lines i'll drop some money off of it.
Old May 22, 2003 | 10:51 AM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
Well, i do want the lines with them. im just tryin to get the money for them. i get paid every week, so it shouldnt take long.
Old May 23, 2003 | 12:40 AM
Soulless's Avatar
Car: 1989 IROC-Z
Engine: TPI 350
got any pics of the back discs?? and are the slotted and cross drilled, or what??
Old May 23, 2003 | 03:48 PM
Kandied91z's Avatar
yes i have the gm discs in the rear right now until i can find a way to modify the brackets to fit an eradispeed rotor in the rear to match the front.
however, i'm not selling those until i find a way to replace them. the stock plain rotors look terrible.
you can still get them through gm as well...they are about the same price as the fronts.
Old May 23, 2003 | 03:51 PM
Kandied91z's Avatar
email me and i'll send you a pic of the rear....can't get it to upload here.
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
