New front brakes, but they still lock up
Old Aug 21, 2004 | 09:52 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
And the saga with my younger bro's 1982 sport coupe Camaro continues...
We did a complete brake job up front (haven't done the rears yet). Replaced the pads, rotors, both calipers. Hoses looked okay so we left them alone. I bled the calipers well, and they bled quickly and without any trouble. Old calipers were sticky; pistons didn't move well...too much central NY winter climate experience...it was a woman's delivery vehicle for her business before we got it....saw about 6 road-salty winters....
Even with all of the new parts, the brakes still lock up after you step on them. The car will stop on a dime without pulling at all side-to-side, but the front calipers will not relax off the rotors until you revv the gas and force the car forward against the brakes. Then the rotors turning is enough to push the pistons back in and the car rolls fine again until the next time the brakes are applied. I know for certain it's the front brakes and not the untouched rear ones because I can feel it when the car stops, and can hear the groaning from the front brakes as I force the car forward after letting off the brake pedal. What do you think? Both front brake hoses shot? Air leakage in rear brakes (no fluid leaks that I can see)?
Old Aug 21, 2004 | 11:23 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I would say change the hoses, sounds like they may be collapsing. I almost wonder why you didn't just change them when you did the rest of the brakes. Of course in your climate they may be a real pain to change. With salty roads and corrosion I mean...
Old Aug 22, 2004 | 07:00 AM
Car: 1984 Camaro
Part of the reason was that my brother ran out of cash after buying everything else, and the other part was that I can see that the second we try busting the steel line loose from the hoses, the line is going to break....oh well, guess I'm just going to have to bend the new pieces out. Thanks for the opinion, '92.
Old Aug 22, 2004 | 07:42 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I bought my Z in Colorado years ago when I was out there in school. It had its share of rusted out components on it as well. When I did my front brakes I sprayed to hard line fitting with a rust penatrator a few times before I took a wrench to it. Then the sucker came right off. Maybe you want to try a similar method...
Old Aug 22, 2004 | 04:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Soak them well with a penetrating oil as mentioned; also when the time comes, hold the nut still, and turn the hose off of it, instead of the nut out of the hose. This may save it, and you should then be able to free the nut up on the hardline, and use anti-seize when re-assembling.
Old Aug 22, 2004 | 09:06 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
You know.....Just a hunch, but the problem may not be the hoses although they need to be replaced anyway. Question first: Do the brakes stick everytime you come to a stop?
This really sounds like more of a problem in the master cylinder piston. I'd replace the unit.
Just to make sure, do a quick test to see if your brake booster is properly working. I cant remember offhand (but its in Chilton).
Old Aug 23, 2004 | 06:02 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Heres help
Okay, I used wd-40, and a propane torch. I heated up the fittings on my canadian fire bird, and then tried moving them. If they didn't move I let them cool a little then sprayed wd-40. This usually helped.Some times I had to reheat them. Hope this helps.
Old Aug 23, 2004 | 07:51 AM
Car: 1984 Camaro
Master cylinder malfunction? Ah!! I really hope not! I've never done one of those before...though I suppose there couldn't be an easier car to change one on than a plain-Jane 1982 Fbody. I own the Chilton's manual, so I guess I'm going to have to look up that test...
Old Aug 23, 2004 | 11:41 AM
The test is really simple (look in the troubleshooting section). But I doubt its the booster anyway. Just have to look for brake pedal movement after depressing the brakes and disconnecting the vacuum line to the booster. If your booster was bad you'd have a hard time depressing the pedal.
The master is not difficult. The only pain is bench bleeding it, but the only reason its a pain is because your arm gets tired after repeatedly pressing/depressing the piston. I think the reman ones cost like $30.
Its really not that bad. And they do sell vacuum bleeders at autozone now ($25) to make it pretty easy.
Its 22 years old now, so its probably way past due anyway. Gotta keep up with that damn preventive maintanence!
Also...make sure you bed the pads. The general rule is 30 stops from 30mph to zero. They'll feel REALLY good after a good bedding process.
Old Aug 23, 2004 | 11:23 PM
Re: Heres help
I tried that on my Z28. Once.
That sucker blew and spurted brake fluid all over, mostly on my face (glad I wear <font face="Wingdings" size="5">$</font>!) and I could barely hear anything until the next day because <font face="Wingdings" size="5">M L</font>
Replacing/splicing a line now seems like a much more viable option<font face="Wingdings" size="5">J</font>
Pete
Old Aug 24, 2004 | 05:03 AM
doc76239's Avatar
Engine: TPI 305
Okay???????
If you use heat on a closed system such as your brakes make sure to open the bleeder screw closest to the hard line you are working on. Sorry about leaving that out. If ya heat it up it will blow if there isn't a way to release the pressure. But this method works, I did it on all my rear hard lines. My car came from canadia
Old Aug 24, 2004 | 09:21 AM
Car: 1984 Camaro
hmmm....I think I'll leave the torch out of this, haha. I told my brother to get his wallet ready for doing the work this weekend, so I'll let you guys know how it went then. I did do some tests yesterday, and from what I could tell, the Master Cyl. is fine; however, the driver's side hose is collapsing unquestionably. So both are getting replaced on Saturday, and we might as well do the back brakes at the same time. Fun....
Old Aug 24, 2004 | 02:10 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Replace your front brake hoses.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
