Painting Calipers
Old Oct 28, 2004 | 08:19 PM
klumb15's Avatar
Painting Calipers
has anybody done this??? what kind of paint should i use...i bought a couple bottles of just regular krylon spray paint for metal and some krylon clear coat...will this work or do i need to go out and buy brake paint??? my buddy said that it needs to be brake paint because brake paint is made for higher temps or something...am i alright with just reg. spray paint or should i return the spray paint and get some brake paint???
Old Oct 29, 2004 | 07:32 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Topic has been discussed several times. Do a search.
Old Oct 29, 2004 | 07:51 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
I used dupli-color high heat engine paint. 3.99 a can!
Old Oct 29, 2004 | 03:10 PM
klumb15's Avatar
alright i got some high temperature paint from car quest...the really good stuff...so i wanna do it right the first time...what should I clean the caliper up with to make sure the paint will stick???
Old Oct 29, 2004 | 03:49 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I did this once in my life, and I did use specific Hightemp brake caliper paint. It worked faily well over time. I know others that uses standard hightemp paint and it flaked off just like headers do. These calipers were brand new when I sprayed them. I paintd three light coats over three days and they sat to cure for a week before I installed them. They are now on KED85's car I gave them to him., including the Tokico shocks.
Old Oct 29, 2004 | 03:52 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
I like them better black anodized. It doesn look so kiddish.
Old Oct 29, 2004 | 03:55 PM
klumb15's Avatar
alright..it looks like i'm geting new calipers too...so i'll just paint those, and i won't have to clean the new ones, just rub em down with acetone or something...can you just drill holes in your rotors to give it better cooling or do you have to buy the rotors drilled and slotted??
Old Oct 29, 2004 | 03:56 PM
klumb15's Avatar
mine are gonna be silver so they won't stick out like a soar thumb with the red body paint...i agree, some people paint them some bright colors and they look horrible...
Old Oct 29, 2004 | 04:03 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
The upper ones (10.5'" rotors) were CNC drilled and rebalanced acordingly- You can't just dill them yourself on a drillpress, They need to be percision aligned both radiusly and between the cooling vanes.
The lower picture (12.2" rotors) was casted that way and then "cleaned up" drilled and zincwashed. Its a much stronger process and perfered for rotor integrity. I now have larger surface area enven with the drilled and slotted material missing + I have less rotation weight than the others even though they are larger. drilling made them lighter.
Old Oct 29, 2004 | 04:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does the small amount of mass removed during drilling really make a noticeable difference?
Old Oct 29, 2004 | 05:08 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
They are a 1/4 of a lb lighter each side from the same exact rotors not drilled and slotted. Thats a total 1/2lb less rotation mass AND on the outer 2" of the rotation radius. Even with the mass drill out making less surface area, these rotors have more surface area with drills and slots (67 sq in.) compared to the 10.5 rotors without drills or slots (59 sq in.) AND have more leverage for power.
All in all, the lighter weight larger rotors are about a direct wash in rotation mass because even though they are lighter weight, they are in fact a larger diameter producing more polar weight to rotate- its about a direct wash, yet I have much cooler running brakes and more braking power.
acceleration properties are equal
Braking properties are better.
This is a perfect example how drilled rotors can be a benefit.
Old Oct 29, 2004 | 05:46 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
when i did my ls1 brakes, i bead blasted the calipers and just put a couple coats of rustoleum heavy duty on, and its held up just fine for 7k miles. i painted them red, but atleast they match the car
Old Oct 29, 2004 | 11:14 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
I used high temp paint from por 15 and I just used their cleaner and then their acid type prep stuff and never had a problem.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
