Can I use non PBR lines for PBR calipers?
Old Dec 19, 2004 | 12:33 AM
Abubaca's Avatar
I currently have a 2.77 9bolt with PBR calipers. I'm swapping in 3.27 9bolt with the old style steel calipers but I'm gonna swap over the PBR pieces. Can I use the "old style" brake lines?
I don't see why not, and it would make like a lot easier.
Old Dec 19, 2004 | 05:57 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Use them, nothing specific about PBR brake lines.
Old Dec 19, 2004 | 06:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Forget the below. I finally understand--hey, it's early! PBR to PBR should be no problem.
I may be way off base here, so take what I say with a grain of salt. On my ten-bolt, the iron caliper on the driver's side required that the hard line go to the front of the axel, and if I remember correctly, the hard line went directly to the caliper. When I swapped to PBR's, the hard line on the driver's side went to the rear of the axel and required a hose. The following thread will show what I mean about the PBR lines:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Dec 19, 2004 | 09:46 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you could always get new lines
www.finelines.com
Old Dec 24, 2004 | 07:26 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
same here on my 88' 9-bolt. the drivers side line was a hard line all the way to the caliper. the pbr used a flex line. i replaced the hardline with one from a pbr equipped car.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
6speedIROC
16
Mar 15, 2023 08:33 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
