LS1 Brakes
Car: 1987 Z28
LS1 Brakes
Ok, i'm sure this has been posted on here many times... I spent some time searching and didn't really find what i was looking for though. Basically I came across a good deal on a complete LS1 brake set up (ls1 buddy bought a baer kit). I'm wondering if there is a good write up somewhere on how exactly to do it, and what i'd need. I'm also curious if the brackets are the same as the c5s? Basically, if i do whatever i need to to get the ls1s on my spindles can i later upgrade to c5 calipers/rotors just by buying them, or would i need a different mounting set up? Oh, and i have 10 spokes so i have no worries about the wheel clearance issues. Thanks.
boy, you are probably going to get flamed for this even though you did say you searched.
You can check out technical article section of this site. Although LS1 install link seems to be broken. Here's one from the same fbody.com site that should work:
http://www.fbody.com/tech/details.cgi?id=30
As for LS1 vs. C5 I want to say calipers are interchangable but I am not 100% positive. You should wait for someone more sure of this one. I still haven't looked at much of brake stuff for my own car.
And how come I hear of so many 4th gen buddies getting baer kits and giving us their left overs. Why can't we get baer kits? Are they that much better?
4thgen= Heavy peice of crap= needs more brake to stop...
I say if you get a deal on complete LS1 setup, go for it (depends on the deal of course)
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Originally posted by VILeninDM
well, if that is the case, why are so many of us switching to them?
This means that there is less force to stop, meaning you don't really need brakes as big.
Car: 1987 Z28
Maybe because a Baer kit for our cars that is the same **** as ls1 brakes runs like 1200+. So it doesn't make sense for us to buy that kit when we can just get ls1 brakes. They don't quite have the same upgrade options we do. There isn't much they can do besides vette or aftermarket...
Also, thanks for the link, but... That's to swap ls1s on to an LT1 camaro, i'm looking for info to put the LS1s on my 3rd gen.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
My spindles are done and brackets are on :-)
Grease the bearings and do the final assembly and mine are ready to go. Wayyyyyyyyyyyyy better than the puny 10/5 inchers we got from the factory :-)
Search under "1LE Alternative" in the brakes section(obviously).
If your not making the pieces/hubs yourself talk to ebmiller88.
He is the man and superduper knowledgeable on what u need to do this swap .
later
Jeremy
later
Jeremy
how about this link then.
That link basically outlines everything you need to do to get C5s onto your car. LS1 and C5 calipers are interchangable. The only difference between the two is that C5 has ribs for more structural support. ( I am not sure if they are ligher, or about the same in weight)
Car: 1987 Z28
Thank you for that site, that has a lot of what i was looking for. Also, thanks for the info on the ls1/c5 calipers.
LOL, weird
Hopefully my car will be a whole hell of a lot faster by summer, if i put everything on
Originally posted by crazy3rdgen
da mn you have a similar name as mine!!
and cars white .. ur faster tho lol
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
These are mine after I got some Por-15 on em. The whole setup is pretty easy to do. Almost ready to put mine on.
http://img.photobucket.com/albums/v3...n/377cfef4.jpg
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i love my ls1s, the car stops soooooooo much better now
the only downsides are you cant run 15s without grinding on the caliper(i hear many arguments both ways on doing that)
and ive also read that under extreme conditions the calipers have the tendency to suffer from piston spread, but i dont at what level you would experience that
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
I'm sorry to have to point this out, but there is a complete guide to installing LS1 brakes on the 3rd gen car in the FAQ Board. Its on the first page of threads. It is 9 pages, but it is well worth your time. I even think the thread is clearly labled with LS1 in it. What kind of searching did you do???
On another note, I never would have imagined that there would be a 3rd gen Fbody owner who would be against bigger and better brakes. Now I have read it all!
Car: 1987 Z28
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
