bubble flair brake lines
Old Dec 29, 2004 | 04:03 PM
rsczruba's Avatar
I need help with a brake line ! it is a 6mm line with a bubble flair. no auto parts store carries this and the dealer in town has to make it . and said he doesn't do brake lines can somebody help me by pass this garbage setup. It is the main brake line from the frt. of the vehicle to the tee in the rear
Old Dec 29, 2004 | 05:16 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
1.) GM Metric to 3/16" (double flare)
2.) 3/16" to 1/4" adapter.
from there, we used 1/4" line to the 1/4" union (1/4" is like 6.35 mm) hooked to the 6mm line on the other side.
I had the same exact problem. do a search under my name and metric and you can find the post. Holpe this helps some,
I also found these at CarQuest.
Old Dec 30, 2004 | 08:39 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I wouldn't suggest for anyone to use this but do use it myself. I use a 1\4" tube. You will need free up the metric fitting a little, if I remember about 6.5mm. Then use the first part of a sae double flare and you're done. Might be an idea to practise on a scrape piece first.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
