Rear disk options for Ford 9"
Old Jan 10, 2005 | 09:00 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Hey, I am currently running a Ford 9" rear end. My question is, what is a good disk brake kit to buy to replace the crappy drums. This needs to be affordable also.
Old Jan 11, 2005 | 02:09 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Here's a few threads on the subject
https://www.thirdgen.org/techbb2/sho...t=%2Atorino%2A
For the record paertaining to the first link- we have a 4.5" bolt pattern and a 4.75" bolt circle. Most will reference the bolt circle, not the pattern. Bolt patterns are measured from stud center to stud center on a star pattern. Bolt circle is the diameter of the center studs from the center of the hub.
Old Jan 13, 2005 | 08:31 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
If you want to do it real cheap and don't mind to doing some welding / fabricating then check out this link. http://www.speedwaymotors.com/xq/asp...qx/product.htm
You can either run their complete kit or you can do what I did and use either stock 10.5" camaro rear disk or 4x4 blazer front disk and cut the bracket they sell down to fit the smaller rotor. The difference between the blazer and comaro disk is that the blazer disk has less offset. Only down side to this swap is no e-brake, I guess you could use stock camaro rear calipers too since they have the same bolt locations, then you could rig up your e-brake.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
draco
Oct 4, 2015 09:25 PM
Warlocksirix
Sep 3, 2015 12:26 PM
InfinityShade
Aug 22, 2015 08:00 PM
