important rear drum question!
Old Jan 21, 2005 | 04:11 PM
thirdgenhero's Avatar
Car: 1984 z28
Engine: 305 H.O.
ok so here is the story. Yesturday, i decided to put a new wheel cylinder in cause my old one had been leaking, i get everything off except the one anchor bolt that holds the backing plate to the axle. its the bolt that all the drum springs connect too. well anyways it wouldnt budge not even with a impact wrench, so after about 4 hours of trying to get it off we finally cut it off with the plasma cutter... well anyways i have came to find out that GM no longer makes this bolt and cannot find one anywhere... so you guys have any ideas as to what i could do? any help would be much appreciated..thank you
Old Jan 21, 2005 | 04:45 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Junkyard run!!!
Old Jan 23, 2005 | 11:42 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
I know this sounds like a really stupid question but, how do you replace the real wheel cylinders? I am putting a 3:42 posi rear end into my 85 z28 and the wheel cylinders are froze up! I cant find any bolts other than the four holding the plate to the axle tube!
jaridjohn
Jul 8, 2024 03:49 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
