E brake
Old Mar 5, 2005 | 06:57 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
E brake
how do you tighten the e brake? or fix it
Old Mar 5, 2005 | 09:49 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
First off, do you have rear disc brakes? If you do, there's a flaw in all stock 3rdgen disc brake rear ends that causes the handbrake cable to stop working, and eventually will lead to the ebrake being applied all the time.
My Camaro suffered from that and actually managed to light the rear pads on fire (thank goodness I was only running around the block for a test run and not trying to hit the freeway).
If you do have rear discs, the handbrake is easy to fix but the brake may be "ratcheted" in, requiring an overhaul of the calipers.
Edit: Check the thirdgen.org tech articles for more information, again, if that's your problem...
Old Mar 6, 2005 | 06:59 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can rebuild the calipers with the recall kit;
There's an adjustment screw and nut above the driveshaft in the trans tunnel, you can also tighten it there.
Ed
Old Mar 6, 2005 | 09:22 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Edit: Check the thirdgen.org tech articles for more information, again, if that's your problem... [/B]
didnt see it
Old Mar 6, 2005 | 09:29 PM
Crayz9000's Avatar
Engine: LB9 5.0L
Sorry, should have posted a link to the article... Anyway.
Q: Do my rear disc brakes need to be adjusted?
A: A technical service bulletin described this for early-mid '80s rear disk brakes. It seems that the rear disks in these cars would be adjusted by applying the emergency brake. When you pull the emergency brake lever up, the lever turns this little device called an actuator screw. This little screw type device is also on a ratchet, so that pulling the e-brake up, turns the screw. But letting go allows the ratchet part to function and set the pads at that time. So, using the emergency brake is mandatory for maintaining the rear disk setting on early model rear disk units.
But, here's the problem with them. There's a little spring on the actuator screw assembly that allows the pads to back-off from the disk a little bit before the ratchet mechanism is engaged. This must be done, otherwise full brake pressure would be left on the pads when the e-brake is released. Well, that little return spring K-factor was not correctly chosen from the factory, and the result is that the ratchet NEVER functions after the actuator screw gets a little dirty. Hence, the pads simply work their way out all the way when the e-brake is used. Using the e-brake all the time seems to keep the actuator free for a longer period of time, but even with the correct spring weight and screw, the e-brake is required to adjust the parking brake actuator.
The TSB states that cars with a manual tranny are eligible for a free fix as the e-brake is required to park the car, but the auto is not eligible. Why? Only GM knows. However, fixing it yourself should be relatively easy. The rear wheels are removed, and there is a nut on the back side of the brake caliper that holds the parking brake lever. Remove the nut, lever, and soft grommets. Put a large washer over the shaft to act as a spacer, and then put a wrench on the hex of the shaft, and tie it down with the nut. Turn the wrench to back the brakes off. After a while, this will over travel, as if there was a one way clutch. Tighten the shaft to see where the hex is when the pads are tight agains the rotor. If it is in a spot that the parking brake lever will fit, and turn about 1/3 of its travel to tighten apply the brake, then it is good. If not, try again.
This will remove some of the brake pedal slop also. It's supposed to be self-adjusting (apply parking brake thirty times), but it is common for it not to work.
Old Mar 27, 2009 | 08:27 PM
KN1GHT's Avatar
Car: 1989 TA
Engine: 350tpi
Axle/Gears: 3.73 posi
Re: E brake
where would i find the kit to fix this problem. my brake just recently stopped working and now the light will not shut off
Old Apr 23, 2016 | 12:36 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Re: E brake
Is it normal for brake fluid to leak out of parking brake shaft when trying to adjust?
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
