drum to disc??
Old Mar 16, 2005 | 07:22 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
drum to disc??
i have an 86 z-28. it has a stock 10bolt rear with drums brakes. im looking to swap it out for a posi unit from a 91 z-28 with disc brakes. when swaping from drum to disc is there anything i need to change? or will i be able to bolt the new rear up and just bleed the brakes?
Old Mar 16, 2005 | 09:02 PM
ScreaminDeamin85Z's Avatar
e-nrake cables is the only thing you need to change i believe.
Old Mar 17, 2005 | 09:17 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I think the cables will work but you may have an issue with the e-brake adjuster in the tranny tunnel, the lines may be to long or not fit the adjuster bracket.
Ed
Old Mar 17, 2005 | 11:44 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I jsut swapped PBR rear discs (same ones you have z28crazy) on my existing 86 rear end and i ordered e-brake cables for an '89 4wheel disc camaro from napa and they fit perfectly.
Old Mar 21, 2005 | 08:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could change to the J65 (4 wheel disc) master cylinder if you want the larger piston, but the current M/C is fine.
But you might want to also switch the proportioning valve out.
Old Mar 22, 2005 | 02:16 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Did this swap. Yes, you will need to change the proportioning valve for the rears to function properly.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
