Anyone try a fourth gen/LS1 master cyl on a Third Gen brake conversion?
Old Mar 28, 2005 | 07:38 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Just like the topic says. I am wondering if the LS1 master cylinder has been tried and what you think of it?
Old Jun 23, 2005 | 07:18 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
ttt
Old Jun 23, 2005 | 08:41 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Someone has... It was at the tail end of one of the long LS1/C5 brake threads.. Keep searching..
Kevin D.
Old Jun 30, 2005 | 03:27 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
I read that somone did it, the only thing is there isnt a perportioning valve on the 4th gens, its built into the ABS
but the mastewr cylinder and booster should work
do a search i know i seen it somewhere
Old Jul 2, 2005 | 08:22 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I just got one but I haven't installed it yet. It looks like you might need to redo the lines from the MC to the Combo valve. The ports on the LS1 MC are closer to the booster so it screws up alignment. You could also just cut half an inch out of the bracket for the combo valve and reweld it.
Old Jul 2, 2005 | 11:28 AM
IROC_5796's Avatar
it would be easier to route the front line right into the MC and get a wilwood porportioning valve for the rear, may have to change the end that screws into the MC but that doesnt take long to do.
Old Jul 5, 2005 | 12:26 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
Fits like a charm
just tweak the lines a little.. I got some serious fade with my LS1 brakes tho Startin a thread to see if anyone can throw me some pointers
Old Sep 24, 2005 | 08:37 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Originally posted by Ace
Fits like a charm
Any updates? I've gathered everthing to do this swap myself and am interested in any road-blocks people have run into...
Old Sep 25, 2005 | 05:33 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Roostmeyer has one installed. Other than that I have no other input, I plan on using one on my '70 but that's a long way off.
Ed
Old Sep 25, 2005 | 10:06 AM
BOTTLEDZ28's Avatar
Transmission: A4
what are the advantages to doing this swap? I have a 4th gen disk rear in my car which originally had a drum rear. I just added the disk rear w/o any proportioning valve at all. Not sure if my car would stop better if I added one but Ihavent got to that part in my project yet. Is the 4th gen on better and if so in which way? is it smaller?
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
