C5 brakes with dropped spindles
Old Apr 5, 2005 | 09:45 PM
VILeninDM's Avatar
I've read the spindle group purchase thread several times and this was mentioned in there, but I couldn't find a definite answer, so I am starting another thread here.
I recently got a set of drop spindles. Pictures here: http://dxm004.homeip.net/gallery/vie...mName=04-04-05
Now the question is: will these work as is with C5 brake conversion brackets? Or do I need new brackets? It appears that brake shield mounting holes are in exactly same position in relation to the spindle, so I am hoping the answer would be I can go ahead and put brakes on them. But I wanted to see what brake/suspension experts would say about this one.
I also wasn't sure what the best way was to measure exact dimensions
Old Apr 5, 2005 | 10:32 PM
VILeninDM's Avatar
Just took two more pictures with brackets layed right over the brake shield holes. They seem to fit perfectly, but again.... experts?
Old Apr 6, 2005 | 12:53 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I'm not exactly an expert, but here are my thoughts:
I see no reason for it NOT to work. The drop spindles are specifically designed to reuse all the factory brake hardware, which means the backing plates and caliper mounts should mount up exactly like the stockers do. All the holes should be in the same places, and the conversion should work just the same as it would on a stock spindle. I'd like to try it and see.
Old Apr 6, 2005 | 04:39 PM
VILeninDM's Avatar
my concern is that we are using brake shield bolt holes. Those holes are not exactly critical part of the component in the original design. I agree that brake mounts must have moved along with the spindle when they designed the thing, but who knows what they would have done with brake shield because most people wouldn't care about the shield that much.
Look at C5 conversion, we completely threw away the brake shield as unnecessary item (as far as I can tell)
Old Feb 10, 2006 | 06:10 AM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
I am off topic, but what did you pay for your drop spindles? I have been looking for a set for almost 2 years now!
Old Feb 10, 2006 | 06:17 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I did a C5 setup for a guy with dropped spindles on his S10 truck, sight unseen, and they bolted right on. They should fit just fine.
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
Ghettobird52
Apr 21, 2020 08:44 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
