Brakes are awesome on first pump
Old May 21, 2005 | 12:20 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
When my car sits overnight, the first pump of the brakes is excellent, then they fade to decent. The car has to sit a while for this to happen. I dont understand, anyone have any ideas?
Old May 21, 2005 | 05:33 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
how are you flexable hose on the brakes(usually on fronts only)? ever been changed... often the corode inside or collect junk that allows fluid in fast on the push and the return is slow since there i not much return pressure. or you have a leak somewhere that is getting air in the lines but i would think then they would always suck.
jeff
Old May 21, 2005 | 05:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Brakes are awesome on first pump
You're talking about while the engine is still off?
Old May 21, 2005 | 07:24 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I dont know when the lines have been changed. Yea this is with the car running.
Old May 24, 2005 | 09:32 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
maybe the master cylinder is leaking...as in allowing fluid back into the resivour... Usually when that hapens the brake light will come on...but maybe thats broken too..
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
