Top 5) cheap - brake upgrades starting with a 4-wheel disc 3rdgen!
What would be the top 5 things to do to a stock 3rdgen that already has 4-wheel disc brakes?
and are relatively cheap and can help braking times dramatically?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
how cheap?
good tires, and good pads go a long ways.
beyond that, you start looking at C4HD, C5, LS1, wilwood, etc.
rubber rots, anyway the rubber line expands if tons of force is applide to it.... witchs means, all that froce thats now expanding in the rubber line could have been froced to the cailpers makeing the brakes less like a sponge
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
I've my new rotors and bearing on order.
If you don't mind me asking is there a trusted brand for the ssb's?
what would you choose?
cheers
cheers
Go for the LS1's and don't look back. Definatly glad I did.
I think with all the parts I kept the whole swap around $200 and they look like a million bucks.
Gets my vote for best bang for the buck as far as brakes go.
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
Rather than start another thread.
question.
I know front brakes are larger than rear and do a larger percentage of the braking, but upgrading the just the fronts to an even more powerful braking system cause a problem in braking say.
in a turn or in the rain or both.
I cant think of a way of wording it at the moment. maybe someone will understand (at work, typing quick)
question.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Any of the swaps documented on this site will get you at least close as the factory as far as wheel lockup. That's not saying much, but you could always add an adjustable proportioning valve to dial out some of the rear brakes.
While doing my suspension rebuild on my '89 IROC-Z I also did some minor stuff with the brakes. One of my lines was frayed and I didnt trust it so I had to replace it. And if I had to do one side I might as well do the other, so both fronts. Since I plan to goto bigger brakes later I didnt want to buy any of the good stuff (steel lines, best pads, etc) so I went the budget route. Spent a total of $118 to refresh the front brakes. The fresh rubber line is noticably stronger than the old ones but the real test will come when its time for test drive. I know steel lines are probably better but for the price this is great ($25 each). Took the rotors and got them turned, then busted out the tape, newspaper, and 500 deg engine enamel and painted the hubs up nice. They look awesome and cost a total of $25 to do both. The pads are carbon-metallic, some unknown brand ran me $42. I'll get pictures and test it out this weekend. This isn't some awesome upgrade but around $100 for fresh lines, pads, and rotors ... I'm really happy so far.
Car: 89 Iroc
Engine: 305TPI
Originally posted by ebmiller88
Secret my man, secret...
Ed
Ed
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I am using Forged Billet Superlites (FSLs) but I've yet do decide on which rotor I will use. I'll probably do something with both sizes I'm working on but recommend one over the other or for specific applications, and maybe come up with something with a 2 piece rotor once I have the time to sit down and do some measuring. I'm busy as hell now...
Ed
Ed
Here's that picture I promised of my new front brakes. Not really a performance upgrade, but more of a servicing the brakes and then painting everything to make it look upgraded (lol). This cost me about $100 for all the parts to do the front end (lines, pads, rotors turned, paint and tape, etc). Rears are next ..
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
