c5 brake line question.
Old Jul 19, 2005 | 03:54 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Hey guru's. I have all of my stuff ordered minus my brackets and hubs. And i got to wondering if theirs a source for braided brake lines that will work on the early cars(82-84).
Im doing the c5 swap. And id like the braided stainless lines as my stock lines are 23 years old now.
Does anyone have an earls part number that will work with this application, or can at least help me devise a solution. Thanks a bunch.
Old Jul 19, 2005 | 06:20 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Spohn should have them in stock although you can piece them together yourself if you don't mind calling Earls' and getting the parts yourself.
Ed
Old Jul 21, 2005 | 08:40 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Classic Tube custom make a set, (I have them on my '84) with the C5 caliper fitting and the Camaro line fitting.
Old Jul 21, 2005 | 11:39 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Ed
will this work, right in place of the stock line, even when using the upgraded brakes?
Old Jul 22, 2005 | 07:35 AM
ebmiller88's Avatar
They should, even with the round banjo bolt fitting. Otherwise, you can make a custom line using a separate line fitting, brake line, and banjo fitting.
Ed
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
