New Brake Pade question
Old Jul 26, 2005 | 02:49 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
New Brake Pad question
Ok well I found this odd figured I would ask around. I just got new brake pads...poped the old ones off...went to pop the new ones in and I noticed the new ones didn't have the pin. The old pin wouldn't come off so...will it hurt to not have it? Did the auto place give me the wrong brakes? or...what?
Heres a pic of what im talking about:
Old Jul 26, 2005 | 10:26 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yes, you will want that pin.
The old one will come off with some wrestling.
Old Jul 26, 2005 | 11:13 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If you break the clip or want to get new ones you can get them in a brake hardware kit. Otherwise just reuse the stock one.
Old Jul 27, 2005 | 07:35 AM
crrllmich's Avatar
Engine: L03, LS1
It looks like the new pads wont even accept the peice. I will try to take pictures in a little bit.
Old Jul 27, 2005 | 09:00 AM
crrllmich's Avatar
Engine: L03, LS1
Ok well I got the old peice off and the shim BUT heres no way to put them on the new pad So did the guys over there give me the wrong pads?
Old Jul 27, 2005 | 01:07 PM
crrllmich's Avatar
Engine: L03, LS1
Will it hurt if I just leave it off?
Old Jul 29, 2005 | 02:44 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Do not do this. The brake pad will rattle around and will have uneven wear along with many other problems.
Old Jul 29, 2005 | 07:21 AM
crrllmich's Avatar
Engine: L03, LS1
Ok so then back to my previous question. Do I have the wrong pads?
Old Jul 29, 2005 | 11:44 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
We can't answer that without a picture or a part number
Old Jul 29, 2005 | 01:32 PM
crrllmich's Avatar
Engine: L03, LS1
Well its the same exact pad except on the back it doesnt have the peice that holds the pin. I am gonna go to a different car parts place today and have them pull the pads and see if I have better luck. If that doesn't work I will pull them off the car and take a picture.
Old Jul 29, 2005 | 01:39 PM
crrllmich's Avatar
Engine: L03, LS1
Doesnt have this.
Old Jul 29, 2005 | 06:30 PM
crrllmich's Avatar
Engine: L03, LS1
Ok problem solved I had the wrong pads. New ones have the peice I needed.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
