Ceramic Brakes
Old Aug 9, 2005 | 08:58 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Ceramic Brakes
I know alot of you want to upgrade to huge brakes, but if you want something that works well with the stock stuff, just get some Ceramic Brake pads. They work like a dream. I'm even using them with stock non-cut rotors.
Old Aug 10, 2005 | 01:09 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You are still putting a band-aid on the problem. The stock brakes are nothing short of junk.
Old Aug 14, 2005 | 08:20 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Ceramic pads also wear-down rotors about 5 times faster than semi-metallics.
Old Aug 15, 2005 | 05:10 PM
kevinc's Avatar
Car: 1982 Z28
Re: Ceramic Brakes
Some day if you ever learn physics, you'll understand the value of extra rotor diameter and pad surface area. Until then, ignorance is bliss.
Until you put it on a road course or otherwise use them hard, at which point they typically fade to nothing. I tried Bendix and Raybestos ceramics and they both faded in less than 20 laps on the local track. Vette guys with massive rotors and excellent calipers have reported the same outcome.
They're excellent for street use, though...very little dust, no squeal, and excellent wear life.
Not trashing you for working with what you have, just pointing out the ignorance driving your belief that magic pads make 10.5" rotors and single-piston calipers overcome the laws of physics.
Old Sep 9, 2005 | 09:00 AM
Verviticas's Avatar
Engine: L98 5.7
Stock breaks, properly maintained are more then enough for the street. Mine were, after i fixed them. I couldn't ask for more on a stock car.
I never paid more then 14 dollars for a rotor on my car (the other pair is 12) So what if you replace you rotors as often as you do your pads instead of once every three times (and still pay to get them turned) or whatever you run.
So he noticed an significant improvement over he OE pads with aftermarket pads. This somehow defies the laws of physics? OE pads are JUNK, 95% of the pads out there are better then the junk they made in 83. Don't be so quick to put down someone findings, just because you "experts" know everything.
You guys are quick to judge and mean to anyone who isn't intensly expirienced. It seems you only take people seriously when they have a blown 383 and zo6 rims. The guy liked a product, no need for one of you to douce him in gas and the other flick the match. Im not comming to thirdgen.org anymore.
Old Sep 9, 2005 | 09:12 AM
kevinc's Avatar
Car: 1982 Z28
Don't let the doorknob hit ya in the butt on the way out.
Old Sep 9, 2005 | 06:55 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Stating facts such as," Stock 10.5" brakes suck", or "ceramics were down your rotors faster", or "you're band-aiding a bigger problem" may be a little more direct and different response to the original post than what you expected (and the poster) but I would much prefer an honest, direct response to a post then some of the crap hyperbole that I've been fed here on occassion.
If reality is too harsh for you......
And, good luck with those $14.00 rotors!!
Old Sep 9, 2005 | 07:34 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Wow this is harsh.
Kevin
Old Sep 10, 2005 | 06:33 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
