Brake lines and a little more
Old Sep 16, 2005 | 04:34 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Is there a difference in the banjo bolt side of the brake lines between the LS1/ZO6/BAER (PBR) calipers?
I thought I found the info at one point but, should the pads overhang the rotor? If they do.. say by a 1/16th or so, would that be a bad thing?
Old Sep 16, 2005 | 09:07 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
All banjos for C4/C5/ LS1/1LE/rear PBRs will interchange although they have different part numbers due to the bolt heads being designed a bit differently. I buy the C5 bolts as they are the cheapest new.
A little overhang will be OK but not any more than what you mentioned. It may cause cracking or something like that, and it also takes away from pad surface area.
Ed
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
