drum to disk
Old Sep 19, 2005 | 04:55 PM
package's Avatar
Car: 1987 camaro lt
Engine: 305 4 barrel
Transmission: th 700r4
drum to disk
if im switchingaxle assemblys and putting on a disk rear in place of a drum do i need a proportioning vlave right off the bat?
Old Sep 19, 2005 | 09:07 PM
The Wizard's Avatar
Car: '85 Z28
Engine: 355
Transmission: TH350
It will work w/o switching it but not properly.
Old Sep 19, 2005 | 09:24 PM
package's Avatar
Car: 1987 camaro lt
thanks for the info ,everything is exactky the same from axle to axle apart from the brakes.the brake lines look like they will bolt direc;y in is this so ?
Old Sep 19, 2005 | 09:31 PM
The Wizard's Avatar
Car: '85 Z28
Engine: 355
Transmission: TH350
Use the disc brake brake lines. The rubber hose that goes from the tee to the line on the body will hook right up.
Old Sep 20, 2005 | 12:24 AM
package's Avatar
Car: 1987 camaro lt
thanks for your help,when you say the T you mean the t located on the diferential housing correct?will i need a proportioning valve imediately or can it be driven after hooking all the lines up?
Old Sep 20, 2005 | 06:38 AM
The Wizard's Avatar
Car: '85 Z28
Engine: 355
Transmission: TH350
Yes, T on Diff. housing..... No, you don't need prop. valve right away but get it asap..... I'm running w/ the wrong one but I have the right one just not the time to put it on.
Old Sep 20, 2005 | 05:54 PM
package's Avatar
Car: 1987 camaro lt
thanks it would only be a cou[le of weeks i ordered the adjustable from jegs.but i also got the one off of the car i got the rear from.
6speedIROC
16
Mar 15, 2023 08:33 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
dbrochard
Sep 25, 2015 04:56 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
